Results 1 to 10 of 16
Thread: a few simple questions
    Nov 2009
    Strathfield, Sydney
    Can i set my folding mirrors to fold when i lock the car?
    How do i turn on my rain sensor?
    Apr 2009
    Melbourne, VIC
    Not sure about the mirrors but probably not given that the switch is disable once to get to the point where you are ready to lock your car. I.e. turn off the car, take the key out of the slot and open your door and the mirrors won't even fold with the switch.
    Rain sensor is always on. The first wiper setting (one click up on the right hand stalk) is where it has to be for the wipers to come on and go off automatically though. You can set the sensitivity on the same stalk.
    Canberra
    Quote Originally Posted by 111 View Post
    If you want auto wipers as you drive along then as Rocket says above.
    If you want your windows (and sunroof if fitted) to close if it starts raining while the car is locked then depending if you have the full screen display you can set it yourself in one of the menus (your owners manual tells you all about this stuff).
    May 2009
    Quote Originally Posted by gregozedobe View Post
    Maybe on your Skoda or the MY10 Passats, but my 09 doesn't have this option and I don't think the MY08's and before have it either. I think it needs to be VAGCOM'd.
    Pete
    MY13 Octavia vRS TDI DSG
    Canberra
    Quote Originally Posted by Pana View Post
    That's surprising, I know it is available on Golfs that have the full-height screen (ie the panel in between the speedo and tacho has changeable text in the top half as well as the bottom half, the half-height only has text in the bottom half, while the top half has warning lights only).
    Seeing as Passat R36s are a (much) more expensive model I expected they would all have a full height screen, and if they had a full height screen they would have this option available (IIRC it was hidden away in some obscure set-up menu, so not immediately obvious when you are just fiddling with the std data item display).
    May 2009
    I've been through every screen and option on my MFD and there is no rain sensing auto close function. Nor do I remember reading about such an option in the manual - I can adjust the brightness of my footwell lights (which comes in very useful ), but a rain autoclose function does not exist.
    Pete
    Canberra
    OK, I'm officially surprised Does your car have auto wipers ? If it does, it will have a rain sensor, and so maybe the rain sensing auto-close function can be set by VCDS or the dealer software tool. That's assuming you can be bothered, I never leave my windows down when I leave my car, so the rain-close function will probably never actually be used anyway.
    May 2007
    Here is a link to a Skoda thread regarding the mirrors.
    http://www.vwwatercooled.org.au/newf...t=skoda+mirror
    I have tried to make this work, but it doesn't.
    Oct 2009
    Cairns, Qld
    The mrrors thing is in the owners manual and I'm pretty sure the auto wipers only works if you have the lights set to auto as well.
    cheers
    Murray
    Apr 2009
    Melbourne, VIC
    in the manual where? my mirrors only fold in with the switch and i can't find how to make it automatic with ignition. would be handy.
