Results 1 to 10 of 11
Thread: SAT NAV Maps
    Feb 2017
    South Australia
    SAT NAV Maps
    There is a new maps update for the Polo.
    You can get it at the link at the bottom.
    I was hoping to get a back up SD card to put the maps on so that I can keep the original as a back up.
    I cant seem to find a SD card that works.
    According to the VW site, you need a SD-CDA card. I believe that CDA is the brand - does anyone know where to get these from?
    The cards should be formatted to fat-32 with 4096 cluster size.
    Volkswagen Map & Softwareupdates
    Pacific Paradise QLD
    Buy a a 16gb card at Office Works It will be formatted as FAT32 and make sure its a Class 10 Never heard about CDA
    Just buy this SanDisk 16GB Ultra SDHC Memory Card | Officeworks
    Feb 2017
    South Australia
    That's the exact one that I am using.
    Formatted FAT32 and 4960 clusters.
    I copied the Map folder into the root directory of that SD card.
    It didnt work.
    Quote Originally Posted by marcuskmt View Post
    It didnt work.
    Your card just needs to be formatted with the default Which is FAT32 and 4096 BYTES NOT CLUSTERS
    Put it in a PC r/click on drive letter /format hit enter
    It should say File System Fat 32
    Allocation unit size 4096 BYTES
    If it didnt work what is the exact wording of the error you are getting and what is in the root directory of the card
    Some units require you to use a VW supplied card Do you need this or not?????
    You are confusing me as you also have a very similar conversation going in the Tiguan thread .
    So do you have two cars with different units requiring different map versions or what??????
    Feb 2017
    South Australia
    That is correct. I have a Tiguan 2017 and Polo 2019.
    The Polo stores all it's maps data on a SD card.
    From what I've seen, only the original SD card works. I cant seem to find a SD card I can copy over the data to and get it to work.
    This is the same with the new maps I downloaded. It doesnt work on the 16GB fat32 Sandisk that I have.
    Thats right it wont as the VW card seems to have a hidden partition that has some unreadable encrytion in it so you cant copy it or use a different card that hasnt got it.
    You have to load an upgraded map onto the original card it seems
    Mazda runs a similar system as I found out when I accidentally formatted a card and ruined it and it cost me $245 for a new one
    Jun 2019
    Vermont South 3133
    I would use SD card clone software as per this link to produce an exact copy of the VW SD card, then download the new maps and overwrite the map file on the cloned SD card. This should preserve any hidden sectors and not compromise your original SD card
    The Best Free SD Card Clone Software: Cloning SD card easily
    Apr 2010
    Rowville,Vic
    Tried the cloning software and set it to clone all bytes etc. Did not work. Cloned SD card nav data would not display on the media unit. I used a 32 gb card, would you know what size card needs to be used?
    MY19 Polo GTi 2.0 DSG
    Previous VW cars:MY16 Polo GTI manual, 2007 Jetta 2.0 TDi manual, 2001 VW Bora V6 4-Motion - flooded away
    Apr 2010
    Rowville,Vic
    Thanks for the info about the Polo's sd card system
