Originally Posted by
NZ_GolfR
Yes, ignore the HUD part since you don't that that.
If it is working you should get the speed signs showing in you AID area, either allow the top row or in the main middle area if you have set it to display there. You should also get a warning about 30 seconds after you start the car to say this function is restricted (I think that is the wording).
You should also be able to adjust the settings for this (warning if you go over the speed etc) in the Car Settings menu on the Infotainment (same place you can change all the driver aid settings and lights etc).
Unfortunately I don't have any evidence in my AID nor my settings menu to indicate it was successful. I double checked my coding and all seems correct.. I didn't do that line in yellow as you said it wasn't needed, also when doing theses tweaks do they need to be completed in order as listed?... cheers Gary
2017 Tiguan R Line 162TSI, DAP, White. Upgraded speakers.
