Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: R-Line High Beam
    Apr 2017
    Beachlands, Auckland
    R-Line High Beam
    Do you have High Beam Assist or Dynamic High Beam in Australia? My R-Line has neither in NZ. Hoping to at least enable High Beam Assist via VCDS - anybody got the exact process for. 2017 R-Line?
    Also finding when lights are on auto, the headlights turn on way to early - even building shadows in the late afternoon will make them turn on. Any way to adjust the light sensor?
    Aug 2009
    Alexandria, NSW
    With the Auto sensor, every one of my VWs have had that issue so I'd say its endemic. I used to ask the dealer to check it at service time but it never really improved. I was wondering with DRLs whether its even having them on auto anymore....?
    2007 GOLF GTI - Reflex Silver | 5DR | DSG | Sunroof | Full Tint | Black Leather
    2017 TIGUAN 162 - Indium Grey | R-Line | DAP | Pano Roof | Full Tint - Ordered 30/3/17 Collected 23/11/17
    Quote Originally Posted by SNOBUM View Post
    SNOWBUM: -Over the years, I've collected quite a few VCDS tweak instructions (from all sorts of web-stes) related in the main to my Golf mk7, which like the Tiggy was built on a MQB platform.
    Here's the instructions from this database for activating HBA.
    1. Select the BCM (@ address hex09)
    2. Enter the magic number 31347
    3. Select Adaptation
    4. Find ENG10578-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent and change setting to present (default on the Tiggy is not present)
    5. Select Coding
    6. Go to Byte 2 and change Bit 0-2 to hex3 (i.e Bit 0 = 1, Bit 1=1, Bit 2 =0)
    7. Select the Front Camera module (i.e. Frt Sens. Drv. Assist @ address hexA5)
    8. Select Coding
    9. Go to Byte 2 and check that Bit 0 is set to 1
    As I said, these instructions are for a Golf mk7, but the car has the same build platform as the Tiggy. If you implement the instructions, please provide feedback
    As for you other question - there is a facility for headlight switch-on level in the MENU. Other than this, there are adjustable threshold levels on the Rain Light Sensor module which is a slave module to the BCM. Here's a screenshot of what's available from my mk7 - your Tiggy will be the same because it uses the same series RLS:
    But there is also an adaptation channel in the BCM for the Tiggy with the intriguing name ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle which translates to RLS_Lights_on_at_Rain-p_lx_Rain light threshold. The standard level that lighting engineers use for twilight is notionally 500 Lux, so the default value for this channel on the Tiggy of 600 Lx makes sense. Try altering this value
    Apr 2017
    Thanks Don - your help very much appreciated - will let you know how I get on.
    Apr 2017
    Hi Don
    I tried the tweaks you suggested to enable High Beam Assist - unfortunately my BCM is the one that only displays all zeros in the coding.
    Have you got any further info regarding that module? I see you mentioned this in the Ross-Tech forum.
    I have adjusted the other settings as per your suggestions, but do not get the Light Assist check box on the settings menu of the entertainment unit
    Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-V2.clb
    Part No SW: 5Q0 937 084 CF HW: 5Q0 937 084 CF
    Component: BCM MQBAB M+ H34 0236
    Serial number: 02001700700531
    Coding: 00000000000000000000000000000000000000000000000000 0000000000
    Shop #: WSC 01357 011 00200
    ASAM Dataset: EV_BCMMQB 017001
    ROD: EV_BCMBOSCH_017.rod
    VCID: 7EF425BAE16C35B19B-802A
    Thanks
    Nigel
    Aug 2016
    Auckland, NZ
    So I think I have managed to have some success here with activating this wit the R-Line LED lights. Here is what I have done (using OBDeleven):
    Make sure Lights are switched off
    Control Unit: Central Electronics (Hex09)
    Adaption - Fernlicht_assistent - Menuesteuerung Fernlichtassistent: Change to Present
    Adaption - Fernlicht_assistent - Erweiterte_Frenlichtsteuerung: Change to AFS, FLA, Fernlicht ueber AFS (mine was originally set to: AFS, Fernlicht ueber AFS) - This was the important change that wasn't documented anywhere else and seems to stop the rest of the coding from working.
    Coding - Long Coding - Byte 2: Change to Hex3 (Bit 0=1, Bit 1=1)
    Control Unit: Front Sensors Driver Assistance System (HexA5)
    Coding - AFS_coding_Light_assist: Change to High_Beam_Assist (Long coding Byte 21 - Hex 20 (Bit 5=1))
    Once I had done this I now have Light Assist showing in the Car Settings Menu under Light Settings:
    R-Line High Beam-light-assist-menu-jpg
    And when I flick the lights stalk forward I get the Light with A in it showing on the AID:
    R-Line High Beam-light-assist-aid-jpg
    Now I just need to test to see how well it works....
    Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
    Oct 2016
    SYDNEY
    Great, NZR- can you manage to record the video footage for steps that you ve been doing, due to it is so risky for the dumbest person like me did not know how to backup before coding, thats why if something goes wrong then it would be one step one life ... hehe ... thank you
    Jun 2012
    Dee Why, NSW
    Quote Originally Posted by theitchy View Post
    Are you using OBDEleven? It's pretty easy to do a backup before coding, and to be honest, it's essential.
    2017 Tiguan 162TSI Highline/R-Line
    2017 Audi S3
    Oct 2016
    SYDNEY
    No, I have not ordered mine yet Glad, however I definitely need your instruction on how to perform backing up. Moreover, backup function does available in OBDELEVEN, Glad?
    Jun 2012
    Dee Why, NSW
    Yes, there's a backup function with OBDEleven.
    2017 Audi S3
