Originally Posted by
MickyD
Massive kudos to Phonebooth for that detailed post, perfectly easy to follow and activated on mine. I had tried previously and failed, but your instructions worked. I did have an error about the dynamic cornering lights, but it went away by itself.
Glad it worked for you! I found the cornering light errors clear once the ignition is turned off/on after coding is completed.
mr gee
Mine's a SWB and did some coding this morning and now have DLA ticked in the setup menu on the Discover Pro. Where can I find menu 4B though
You might have module 55 (which does the job of 4B) and may required VCP parameters as mentioned by Kamold.
MY19.5 Tiguan Highline with R-Line & Sound/Vision
