Yes stage 1 will tend to tail off, compared to stage 2 which will keep pulling like a train to redline. There's 25kwaw difference at redline and you'll certainly feel that.
Printable View
I am running the APR downpipe and midpipe which removes the resonator and connects to the stock muffler. I’ve noticed with the past few cold days that there is certainly noticeable resonance upon start up, however after driving for a few minutes in D it settles down. It’s not unpleasant however, it does draw attention, and I think most people would not expected it from a Tig.
Just got back from tuning...Made 181.5kw@4 wheels, big difference from 5000rpm. Will post pics and other details shortly..
The subframe removal is not required when fitting the downpipe, just need to loosen to get get downpipe in and out.
On the red carpet, it is an old piece of carpet from the house I put in the garage so I don't slip when the floor is wet as grage floor is epoxy coated..
Nice work! Post up the dyno charts if you have them stock vs stage 1 vs stage 2
Pics and details
Downpipe
Attachment 34434
Attachment 34435
Attachment 34436
Attachment 34437
034 Motorsport Dog Mount Insert
Attachment 34438
Dyno Time
Attachment 34427
Attachment 34428
Attachment 34429
Dyno Graphs
Stage 2 final power output
Attachment 34430
Stage 2 vs Stage 1 (Note that the 165kw graph is not used as it dipped at the end because of the transmission playing up on the dyno)
Attachment 34431
Stage 2 vs Stage 1 vs Stock Power Curves
Attachment 34432
Stage 2 vs Stage 1 vs Stock Power & Torque Curves
Attachment 34433
Only drove back from dyno home in peak heavy traffic and rain, Melbourne weather has been ****e today.
In sport can hear dsg farts now even with stock muffler, throatier sound all the way through the rev range so sound better overall. Will see how cold start and sounds once it beds in over the next few days. No time to do any sound clips or videos today, will see how I go during the week.
The dog mount insert has made everything feel a lot tighter. Stop/Start is very firm now and hard acceleration feels alot firmer, dont get that shunt in the driveline when coming off hard throttle...
Was a lot louder but a nice sound. Lots more induction and exhaust noise during hard acceleration, even in normal mode can hear the dsg farts now, cruising at 100km/hr same noise as stock system which I like.
Got an check engine light driving this morning which is caused by the O2 Sensor and new high flow CAT, coding fix will fix this which will get done tomorrow. From the picture of the dump front pipe hangers you can see the end of the hangers are close to the frame, it vibrates slightly at low rpm so getting that sorted on the weekend, other than that really happy with the stage 2.....
Discussed IS38 swap yesterday, supply (new), install, retune will be around 3.5k with the current mods I already have and will see somewhere near 230-240kw@4 wheels. With a larger than IS38 turbo will need intercooler, fuel pump, plugs, coils upgrade..
