Results 1 to 10 of 19
Thread: hardwiring to fuse on tiguan
    Jun 2018
    Hi folks,
    Planning to hook up Cellink Neo battery pack that powers the dashcam by hardwiring to the fuse box. Will this void warranty?
    Or should i just stick to using the cigarette lighter socket?
    Tiguan Highline 162TSI | White | R-Line | S&V | Sunroof | MY19 (
    Sep 2018
    New Jersey USA
    I would hardwire it. Much cleaner look.
    Dec 2006
    Kilsyth, VIC
    Definitely hard wire it. It should have no effect on warranty as long as it's done correctly. I'd make sure you put it on it's own new fuse if at all possible to reduce any future troubles too. It also makes it easy to disconnect, should you ever need to, by just pulling that one fuse out.
    If it caused a short or if you broke trim pieces having it put in, then those things would not be covered. Otherwise you should be just fine.
    Oct 2016
    Artarmon, NSW
    Blog Entries
    1
    Hi jolv,
    I chose the easy way. I used the boot power socket. See attached images. It is fully reversible and works perfectly.
    Regards
    David
    Sent from my SM-N950F using Tapatalk
    Ordered: 2017 build date Tiguan 162 TSI Highline with DAP in Tungsten Silver and rear luggage tray. ETA: late April / Early May. I did not have to wait. I took delivery on 11 March 2017.
    If you want the front lighter socket to always be on, then all you do is move Fuse 40 to in line with the other fuses.
    (Excuse the shocking MS Paint job - I'm at work)
    hardwiring to fuse on tiguan-ljs_5437-768x513-jpg
    Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
    Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
    www.nhbautomotive.com.au
    Pacific Paradise QLD
    Whatever you do DONT STICK WIRES DOWN THE SIDE OF FUSES
    Get one of these They come in standard and Mini fuse sizes. The mini also fits in a Micro socket
    Put original fuse in the bottom one and whatever your battery needs in the top one
    Meter the fuse socket to see which side has power on it an fit it as shown
    I hardwired my cell link into the my golf R. Used an add a fuse on the rear wiper blade fuse if I recall.
    Jun 2018
    thanks folks!
    I've been looking at youtube more about hardwiring and now know that thing i need is called a Piggyback fuse Guess I'll just now need a multimeter to test for the 12V input so i dont get it the other way around.
    Too bad the official handbook does not exactly tell you what those fuses are.
    Jun 2018
    does anybody know how to open the side panel shown in the picture below? the guide did not exactly say how and I've not removed any trims before.
    All I got is this 1 trim removal tool, do I just push the tool in to where the clips are and pull the trim out?
    hardwiring to fuse on tiguan-ljs_5420-2000x1335-image-jpg
    I'm following this guide I found: Dash Cam Install Tutorial – Volkswagen MK2 Tiguan – AutoInstruct
    Oct 2018
    Gold Coast
    Hi Jolv,
    yes the arrows rows indicate where the clips are located. If you push the trim removal tool in to the gap you will be able to feel the location of the clips. Once you have located them use the trim removal tool to pop them out.
    The only thing to note with the Autoinstruct tutorial I found when removing the a pillar trim there are 2 Xmas tree clips that you remove (not 1 as indicated). Aside from that it is a fairly simple job.
