View Poll Results: Do you prefer Traffic Sign Recognition or Navigation Speed Limit
Voters
93. You may not vote on this poll
  • Traffic Sign Recognition
    24 25.81%
  • Speed Limit on the Navigation System
    7 7.53%
  • A combination of the two, which VAG doesn't allow in Australia.
    62 66.67%
Results 1 to 10 of 300
Thread: A guide to enable EU specific features for AU Spec Tiguans
    Oct 2016
    SYDNEY
    Thank you very much DV52 ... I appreaciate this kindness very much .....i struggle backing up these things and already made change for Traffic and LED light. However this would be a big help before i start stuffing up everything ...hehe.....thank you kindly DV52
    Apr 2017
    JHB, South Africa
    Has anyone managed to code rear DRL yet?
    Quote Originally Posted by cabby09 View Post
    caddy: it's done a number of ways - Scandinavian DRL tweak being one of these -Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht>active. But this change also lights-up other lamps like the dash
    Or, you could use the technique below - if you have OBD11 (you 1st need to select Central electrics module):
    and if you have VCDS - it's done like this (you 1st need to select the BCM and enter the magic number 31347):
    EDIT: OK - slight change to the screenshots above which work for MQB platform vehicles prior to MY17 build. If your car has the newer ODX modules (I suspect the new Tiggy has these), then the "Parent" part of the adaptation channel name is Außenlicht_Front (instead of Daytime running lights). If you are using VCDS on the new Tiggy, the full adaptation channel name is ENG10575-ENG115833-Außenlicht_Front-Fahrlicht bei Tag.
    May 2017
    Thanks for this but does this mean it's not possible to activate the rear DRLs without changing the front DRLs? I like the look of front DRLs I wouldn't want to use low beam lights as front DRL. OR am I missing something?
