Page 15 of 15 FirstFirst ... 5131415
Results 141 to 149 of 149
Thread: Gearbox in emergency mode Tiguan 2017
  1. #141
    Oct 2016
    Artarmon, NSW
    Blog Entries
    1
    My 2017 162 TSI Highline (70Km travelled) has just started to show this error message, and I was stuck in 1,3,5,7 with no reverse. We travelled from Sydney to Cataract Dam. It was a hot day. After sitting at the side of the road for about 10 minutes we were "back to normal" and able to gently drive back home. I ran a scan when we got back from the first trip and cleared ALL fault codes to try to eliminate erroneous error codes. That was on 9/2/25. Everything seemed fine until 1/3/25 when we travelled to Campsie from Chatswood. It happened again. The same error with no reverse and only 1,3,5,7 manually selectable gears.
    Also just had it serviced where I replaced the battery with a new AGM battery. 24/2/2025. Is this a factor?
    After the Campsie trip, I carried out a scan (VCDS) and it showed
    1 fault found.
    10668 - Position Sensor for Clutch 2
    P1736 00 (00101000) - Electrical Malfunction
    Intermittent - Confirmed - Tested since Memory Clear
    Freeze frame data
    Fault priority: 0
    Fault Frequency: 1
    Mileage: 70205 Km
    Date: 2025.03.01
    Time: 13:26:47
    Engine speed; 0.00 /min
    Vehicle speed: 0 km/h
    Coolant temperature: 104 oC
    Clutch: Primary Stat : Neutral
    selected gear: GANG_1
    Driving position: d
    Engine Torque: -12 Nm
    Control module temperature: 109 oC
    Accelerator pedal position: 14.8%
    DTC Memory status: 38
    I live in Artarmon. This car is well out of its warrantee period. I did the first 6 services at Alto VW Northshore in Artarmon and the last 2 services at Tyre Power in Artarmon.
    What are my chances of receiving a good will Mechatronic replacement from VW?
    It is bog standard in every respect.
    Which VW Service franchise to i use, as I have read very negative feedback regarding virtually every VW outlet?
    The problem seems to be temperature "sensitive". That is on a hot day going for a reasonable run, it will trigger the problem. Has anyone "received" the Software Update and was it successful?
    Every assistance gratefully accepted.
    Thank you,
    David
    Ordered: 2017 build date Tiguan 162 TSI Highline with DAP in Tungsten Silver and rear luggage tray. ETA: late April / Early May. I did not have to wait. I took delivery on 11 March 2017.
  2. #142
    All you can do is ask, if there wasnt a dsg service at tyre power. I think you'd have a reasonable chance of good will. No harm in asking. I have sent a few Tiguan owners direct to VW in the past year or 2, all got sorted out. They were 2018 upwards cars though
  3. #143
    Oct 2016
    Artarmon, NSW
    Blog Entries
    1
    Thank you, h100vw for your reply.
    Tyre Power did an oil change on the Gearbox on 9/4/2024. They used the genuine VW oil which cost a bomb.
    I am happy to ask (nothing ventured, nothing gained), but based on what I have read, I am very wary to go back to Alto Northshore. I could claim some validity from Alto, as they did my first 6 regular services.
    Is it a case of if rejected by Alto, go to the next closest VW Service and try my luck?
    OR go direct to VW Australia in the first place?
    Thank you,
    David
  4. #144
    Oct 2016
    Artarmon, NSW
    Blog Entries
    1
    Hi h100vw,
    My Tiguan runs fine for short trips. It appears it only goes into "limp mode" (No reverse, and 1,3,5,7 manually selectable) if the oil temperature goes over a certain value.
    Is it reasonable to keep using it while a replacement part is ordered? That way I am not "off the road" for longer than absolutely necessary.
    Thank you,
    David
  5. #145
    Oct 2016
    Artarmon, NSW
    Blog Entries
    1
    Today I sent off an email to VW Australia requesting their generosity to provide me with a replacement Mechatronic Unit (Free of charge).
    I provided details of all regular services (6 from Alto VW Northshore and 2 from Tyre Power Artarmon). I also included 2 full diagnostic log files. One pre last occurrence where All faults were cleared and one after the latest "limp mode" episode.
    I await their reply. I will endeavor to keep everyone updated.
    Best wishes,
    David
  6. #146
    Jun 2020
    QLD
    Don’t hold your breath. It’s a common fault across the Vw fleet that use dsg gearboxes.
    I paid Vw in Brisbane to do a service on the gearbox, they told me that I was wasting my money as they are sealed for life, but did the job anyway. 10,000klms later mechatronic died.
    Vw wanted $3800 (I think) plus labour.
    10 years old and 120,000 klms so no chance of warranty.
    Consumer rights say that you should expect more klms before a critical gearbox failure, but Vw Australia wouldn’t even entertain the idea.
    If you google search dsg failure kilometres it’s 80-120,000 is pretty common.
    I ended up getting a Volkswagon specialist mechanical workshop to fix it for $3600 fitted and programmed.
    This was a Jetta, not a Tiguan.
  7. #147
    Oct 2016
    Artarmon, NSW
    Blog Entries
    1
    Hi lloyddus67, I agree, I am not holding my breath, but it is the first step in a journey. I am fortunate that this problem is still "intermittent" and not terminal. I can use the car freely for short trips. As the old saying goes. "Time will tell".
  8. #148
    Jun 2020
    QLD
    I think I got 4 trips of intermittent before full failure.
  9. #149
    Oct 2016
    Artarmon, NSW
    Blog Entries
    1
    Oh dear. Gently, Gently I must go.
  10. #150
    Oct 2016
    Artarmon, NSW
    Blog Entries
    1
    Hi All, Just a bit of an update.
    I received a reply from VW Australia requesting me to take my Tiguan to a VW Dealer for a Dealer Diagnosis. I took it to Mccarroll's in Waitara today and they performed the diagnosis confirming the need to replace the Mechatronic unit. They also asked for the full-Service history (Not my Log book, but the actual Service receipts detailing exactly what was done and when it was done.)
    Fortunately, I have kept these going back to the original service.
    I am now "sitting" patiently waiting for VW Australia to examine my service history to hopefully agree to supply and install a replacement Mechatronic unit at no cost to me.
    BTW, I have currently paid for the diagnostic. ($220 + $2.42 credit card surcharge) I have been told, this is nonrefundable.
    Also, the Tiguan is still working fine.
    I will keep everyone updated as more info becomes available.
