Results 1 to 10 of 16
Thread: Passat 132 TSI DSG
    Quote Originally Posted by momall View Post
    Thanks. Thinking of replacing the B7 TSI with the 132comfortline plus luxury pack and R Pack...
    Took the plunge and am happy with the R-Line. Its does not come with Adaptive Chassis control. Suits me fine though.
    Interesting, the ride is a lot more comfortable than my MY 13 TSI Jetta with Sport pack.
    Jul 2015
    Melbourne VIC
    average consumption is 8L per 100km
    Apr 2017
    Quote Originally Posted by ylzhao View Post
    Averaging around 10L with R19 wheels.
    Feb 2017
    Quote Originally Posted by zzc2010 View Post
    I got 8L with R19 wheels, but on eco mode all the time though. Just because coasting is only available on Eco mode, it made a huge difference. I got as low as 7.5L at night when there's only few traffic from work to home.
    Apr 2017
    Quote Originally Posted by rave75 View Post
    I will switch to ECO mode then.
    I just wonder if ECO mode puts too much pressure onto the DSG for saving fuels.
    Never want to break the DRY DSG again.
    Feb 2017
    That I don't know. As far as I know, creeping (slowly moving during traffic jam) put a stress on the clutch and will cause premature wear, just like when you drive manual. So you better give a distance between you and the front car then accelerate. Holding the throttle while on the hill to keep it from rolling backwards is a big no no too. You will need to replace the clutch plate anyway sometime in the future but don't make it sooner!
    You will see the benefit of ECO mode when the road is sloping down, that's when you need to take of your foot from the gas pedal. You will see ECO symbol on the lower right of your screen when coasting is on (mine is not virtual display). Coasting will prevent engine braking, disengage the clutch, the RPM will sit at idle speed (around 800 i think) and use the momentum of the car to roll forward. When you press the gas or brake, it will engage the clutch again and deactivate coasting mode.
    I imagine if the road is flat or uphill, you won't really see the benefit of ECO mode. I travel from Parramatta to Chatswood for work (around 25km a day) so I've saved quite a lot in terms of fuel expenses. At night when there's hardly any traffic, I could get even 7L and in the morning it is close to 8L. My long term average sits at 7.5L now. Hopefully this helps.
