Results 1 to 6 of 6
Thread: VAG-COM communication error, no ABS, rear view camera, parking sensors,etc.
    Sunshine coast
    I've recently had my rear view camera no longer working, the rear electric boot not opening properly, and today a lot of dahsboard lights coming on, eg. no abs speed sensors, no parking sensors etc. Am wondering if I can have bad / corroded wiring or a faulty gateway? I tried scanning with VAG-COM, but half the time it says "Unable to communicate". If I try again, half of the time it works. I got halfway through the auto-scan after trying a few times. I also managed to save each error manually by retrying.
    Any ideas?
    [shortened]
    PHP Code:
    VCDS Version 19.6.2.0 (x64)
    Data version20190930 DS308.0
    Chassis Type3C-VW46 (7N0)
    Scan01 02 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4C 4F 52 53
              56 61 62 6C 6D 72 77
    VIN
    WVWZZZ3CZDE0XXXXX   Mileage220840km-137223miles
    01
    -Engine -- StatusMalfunction 0010
    02
    -Auto Trans -- StatusMalfunction 0010
    03
    -ABS Brakes -- StatusMalfunction 0010
    09-CentElect. -- StatusMalfunction 0010
    10
    -Park/Steer Assist -- StatusMalfunction 0010
    19
    -CAN Gateway -- StatusMalfunction 0010
    33
    -Flux Capacitor -- StatusMalfunction 0010
    37
    -Navigation -- StatusMalfunction 0010
    44
    -Steering Assist -- StatusMalfunction 0010
    53
    -Parking Brake -- StatusMalfunction 0010
    56
    -Radio -- StatusMalfunction 0010
    6C
    -Back-up Cam. -- StatusCannot be reached 1100
    Address 01Engine (CDA)       Labels:. 06J-907-115-CDA.clb
       Part No SW
    06J 906 027 DE    HW06J 907 309 B
       Component
    MED17.5.2        05 5359
       Revision
    PAH04---    Serial numberVWZCZ000000000
       Coding
    0404000C24070160
       Shop
    #: WSC 40139 959 131616
    VCID71C70889681165C758-8025
    1 Fault Found
    053271 Please Check Fault Codes in Control Module for ABS Brakes
                   U1017
    015
    Freeze Frame:
    Fault Status01101111
                        Fault Priority
    0
                        Fault Frequency
    2
                        Reset counter
    255
                        Mileage
    220785 km
                        Time Indication
    0
                        Date
    2015.03.12
                        Time
    15:06:04
                 Freeze Frame
    RPM1538 /min
                        Load
    23.9 %
    Speed70.0 km/h
                        Temperature
    97.0∞C
    Temperature42.0∞C
    Absolute Pres.: 1000.0 mbar
                        Voltage
    13.081 V
    Readiness
    0000 0000
    Address 02Auto Trans        Labels0AM-927-769.clb
       Part No SW
    0AM 300 058 Q    HW0AM 927 769 D
       Component
    GSG DSG AG7     431 6563
       Revision
    00043014    Serial numberCU501511237286
       Coding
    0000020
       Shop
    #: WSC 01049 002 1048576
    VCID3FA39EB16EC5C3B79E-806B
    1 Fault Found
    006279 -
    Wheel-Speed Signal from ABS Control Module
                   P1887
    000 Implausible Signal
                 Freeze Frame
    Fault Status01100000
                        Fault Priority
    0
                        Fault Frequency
    9
                        Reset counter
    10
                        Mileage
    220785 km
                        Time Indication
    0
                        Date
    2015.03.12
                        Time
    15:06:04
    Address 03ABS Brakes        Labels3AA-614-109.clb
       Part No SW
    3AA 614 109 BK    HW3AA 614 109 BK
       Component
    J104   C2 450M VDF5 0024
       Revision
    : --H07---    Serial number: 00000005930578
    Coding: 0001914
    Shop #: WSC 05311 000 00000
    VCID77D3369106753BF796-8023
    2 Faults Found
    00290 -
    ABS Wheel Speed SensorRear Left (G46
    004 No Signal/Communication Intermittent
                 Freeze Frame
    Fault Status00100100
                        Fault Priority
    1
                        Fault Frequency
    5
                        Reset counter
    245
                        Mileage
    220785 km
                        Time Indication
    0
                        Date
    2015.03.12
                        Time
    15:06:04
                 Freeze Frame
    Speed68.0 km/h
                        Hex Value
    0x0001
                        Bin
    Bits00000000 00000000
                        Voltage
    13.00 V
                        Bin
    Bits00011111
                        Count
    18
                        Hex Value
    0x0000
    01325
    Control Module for Tire Pressure Monitoring (J502
                 Freeze Frame
    Fault Status01100100
                        Fault Priority
    3
                        Fault Frequency
    9
                        Reset counter
    245
                        Mileage
    220785 km
                        Time Indication
    0
                        Date
    2015.03.12
                        Time
    15:06:14
                 Freeze Frame
    Speed68.0 km/h
                        Hex Value
    0x0000
                        Bin
                        Voltage
    13.00 V
                        Bin
    Bits00011111
                        Count
    191
                        Hex Value
    0x0000
    Address 09: CentElect. (J519)       Labels:. 3AA-937-087.clb
       Part No SW
    3AA 937 087 F    HW3AA 937 087 F
       Component
    BCM PQ47 M    421 0465
       Revision
    BA421001
       Coding
    : 0008000000000000009802805400006403510088426D8D60648046200041
       Shop
    VCID3D5FE4B9A4C9D1A78C-8069
       Subsystem 1
    Part No3AC 955 119   Labels1KX-955-119.CLB
       Component
    Wischer 21061  26  0612
       Coding
    00B795
       Subsystem 2
    Part No1K0 955 559 AH  Labels1K0-955-559-AG.CLB
       Component
    RLS 260612 05  54  0403
       Coding
    0230ED
    1 Fault Found
    02739 -
    Bulb for Tail/Brake LightRight
                010
    Open or Short to Plus Intermittent
                 Freeze Frame
    Fault Status00101010
                        Fault Priority
    1
                        Fault Frequency
    1
                        Reset counter
    10
                        Mileage
    220530 km
                        Time Indication
    0
                        Date
    2015.03.03
                        Time
    00:40:55
                 Freeze Frame
    Term 15 Off
                        Voltage
    12.30 V
                            OFF
                            ON
                            OFF
                            OFF
                            OFF
    Address 10Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
       Part No SW
    3AA 919 475 L    HW4H0 919 475 E
       Component
    PARKHILFE PLA H06 0025
       Revision
    : --------    Serial number56261216601722
       Coding
    349106
       Shop
    #: WSC 99999 1023 2097151
    ASAM DatasetEV_EPHVA2C000000000 002008
    RODEV_EPHVA2C000000000.rod
       VCID
    44A9915DCF23A06FC3-8011
    1 Fault Found
    13637396 Databus
              U1123 00
    [009] - Received Error Message
    [New featureExtended UDS fault detail is only supported by current geninterfaces]
    Confirmed Tested Since Memory Clear
                 Freeze Frame
    Fault Status00000001
                        Fault Priority
    6
                        Fault Frequency
    3
                        Reset counter
    245
                        Mileage
    220785 km
                        Date
    2020.10.19
                        Time
    15:06:03
       Part No SW
       Component
       Revision
       Coding
    0000020
       Shop
    1 Fault Found
    006279 -
                   P1887
                 Freeze Frame
                        Fault Priority
    0
                        Fault Frequency
    9
                        Reset counter
    10
                        Mileage
    220785 km
                        Time Indication
    0
                        Date
    2015.03.12
                        Time
    15:06:04
       Part No SW
       Component
       Revision
    Coding: 0001914
    2 Faults Found
    00290 -
                 Freeze Frame
                        Fault Priority
    1
                        Fault Frequency
    5
                        Reset counter
    245
                        Mileage
    220785 km
                        Time Indication
    0
                        Date
    2015.03.12
                        Time
    15:06:04
                 Freeze Frame
    Speed68.0 km/h
                        Hex Value
    0x0001
                        Bin
                        Voltage
    13.00 V
                        Bin
    Bits00011111
                        Count
    18
                        Hex Value
    0x0000
    Cannot be reached
    Unable to communicate with address 09. Are you sure the doors are unlocked
    132TSI Tiguan Allspace
    Pacific Paradise QLD
    Sounds like what happens when your battery is well on the way out
    Sunshine coast
    Hmm, didn't think about that. I'll put a charger on it overnight to see if it improves things.
    The rear view camera can drop out if the cabling is bad though?
    Quote Originally Posted by iampivot View Post
    Possibly but when my battery started dieing I got a dash full of lights and faults and things didnt work and a new battery fixed it but had to go to dealer to get faults cleared
    It still started the TDI but wouldnt run the electrics
    Nov 2007
    This is absolutely the battery. I have just been through this on my daughter's A1
    Chassis Type: 8X-AU21 (8U0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 55 5F 62 72
    VIN: WAUZZZ8X7HB021217 Mileage: 59870km-37201miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Sad to say, but a charge will not fix this, it may help in the very very short term, but its likely a replacement will be required. ... Unless it somehow is not getting properly changed when driving. Incidentally, that was actually the main cause for the A1. A mostly dead battery (30% life left) and an issue with module 08 HVAC caused a drain on the battery at all times. The charging could simply not keep up with the continuous drain. Ended up with a new battery and a new HVAC module
    Sunshine coast
    I did a charge overnight, and I managed to clear most errors. Still has some communication errors, so I agree I probably need a new battery. The rear view camera still has no communication though, so I believe it's either a gateway or cabling issue. The charger showed 13v this morning, but I believe a good battery should show more than that when charged?
