I just performed a rear brake change (used the EPB service option on Carista android app) and I ran a diagnostic sweep on the CAN bus. Came back reporting speaker errors alongside another CAN coding error (both of these errors were present before I did the EPB service - so unrelated)
I had noticed I don't have a front/rear fader option in the head unit, so I'm not surprised to see this error. But I do have some sound from the rear but most sound comes from the front speakers. Aftermarket Bluetooth works (both calls and music integration).
Does anyone have an idea what the cause might be and how to fix it???
Apparently the original owner had the RNS510 fitted after market (or the Bluetooth unit - my memory on this is foggy) so maybe shortcuts were taken or they had no clue...
Navigation
Part #: 1T0035680L
Coding: 04000402010000A10000 (hex)
Component: RNS-MID
Fault codes:
00871 Bass Speaker Front Right (R23)
00870 Bass Speaker Front Left (R21)
00873 Bass Speaker Rear Right (R17)
00872 Bass Speaker Rear Left (R15)
01523 Microphone for telephone (R38
00862 Antenna for GPS Navigation (R50 / R52)
Radio
Part #: 1T0035680L
Component: RNS-MID
Fault codes:
Telephone
Part #: 7P6035730B
Coding: 0A01000000010101 (hex)
Component: TELEFON
[Failed to check fault codes]
Back-up camera
Part #: 3C9907441
Coding: 30007 (decimal)
Component: J772__Rearview
[No fault codes]
CAN network gateway
Part #: 3C0907530Q
Coding: FDABFF47404612002003 (hex)
Component: J533 Gateway
Fault codes:
01044 Control Module Incorrectly Coded
01303 Telephone Transceiver (R36)
Media player
Part #: 5N0035342B
Coding: 010000 (hex)
Component: SG EXT.PLAYER
[No fault codes]
