Results 1 to 8 of 8
Thread: Abs module coding
    Mar 2022
    Hamilton
    Abs module coding
    HELP PLEASE
    Hi there i have a 2008 vw r36 wagon it has 129k on clock its been parked up in shed for little while battery went dead so replaced i now have 3 dash lights on abs/stability control and rear reverse and fog bulb. Have plugged vcds into it and its missing coding for abs module how can we get a code for it.??
    Post the full autoscan here to be sure.
    But it's likely to be 0001439.
    Mar 2022
    Hamilton
    Saturday,12,March,2022,14:01:07:38195
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4555.4
    Data version: 20210226 DS325.0
    Ross-Tech: Home
    VIN: WVWZZZ3CZ9E019200 License Plate: LCM393
    Mileage: 130000km-80778mi Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 02 03 08 09 10 14 15 16 17 19 22 25 2E 36 37 42 44 46 52
    53 55 56 57 62 6C 72 77
    VIN: WVWZZZ3CZ9E019200 Mileage: 130000km-80778miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    14-Susp. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    57-TV Tuner -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (BWS) Labels: 03H-906-032-BLV.clb
    Part No SW: 03H 906 032 AM HW: 03H 906 032 AB
    Component: R3.6-FSI-EU4 G 2150
    Revision: 5GH04--- Serial number: VWZCZ000000000
    Coding: 0000175
    Shop #: WSC 05311 000 00000
    VCID: 6D87C2DB2198AD53545-8038
    1 Fault Found:
    004506 - Fuel Pressure Sensor (G247)
    P119A - 001 - Malfunction - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 129961 km
    Time Indication: 0
    Date: 2021.12.29
    Time: 03:28:35
    Freeze Frame:
    RPM: 663 /min
    Load: 16.1 %
    Speed: 0.0 km/h
    Temperature: 61.0∞C
    Temperature: 32.0∞C
    Absolute Pres.: 1010.0 mbar
    Voltage: 13.462 V
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 02E-927-770.clb
    Part No SW: 02E 300 012 E HW: 02E 927 770 AJ
    Component: GSG DSG AG6 431 1903
    Revision: 04843012 Serial number: 00000805230567
    Coding: 0000020
    Shop #: WSC 44551 111 44551
    VCID: 127DB1275866D2AB297-8046
    No fault code found.
    Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
    Part No SW: 3C0 614 109 P HW: 3C0 614 109 P
    Component: J104 C4 440 V2 0011
    Revision: --025--- Serial number: 00000785758954
    Coding: 0001439
    VCID: 2B030CC3DF0C63630A1-807E
    2 Faults Found:
    01299 - Diagnostic Interface for Data Bus (J533)
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 19
    Mileage: 130000 km
    Time Indication: 0
    Date: 2022.01.05
    Time: 02:56:39
    Freeze Frame:
    Speed: 0.0 km/h
    Hex Value: 0x0000
    Voltage: 13.00 V
    Bin. Bits: 00011111
    Count: 227
    Hex Value: 0x0000
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 19
    Mileage: 130000 km
    Time Indication: 0
    Date: 2022.01.05
    Time: 02:56:39
    Freeze Frame:
    Speed: 0.0 km/h
    Hex Value: 0x0000
    Voltage: 13.00 V
    Bin. Bits: 00011111
    Count: 149
    Hex Value: 0x0000
    Address 08: Auto HVAC Labels: 3C0-907-044.lbl
    Part No SW: 3C0 907 044 DA HW: 3C0 907 044 DA
    Component: ClimatronicPQ46 132 0811
    Revision: 00132023 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 6393A4E3F75CEB23F21-8036
    Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
    Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
    Component: Bordnetz-SG H54 2202
    Revision: 00H54000 Serial number: 01000008449259
    Coding: E68E8F0700041A00470A00000F000000000B59435C00012000 0000000000
    Shop #: WSC 05124 000 00000
    VCID: 71BFDEAB3DA049B370D-8024
    Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer 200508 022 0601
    Coding: 00046997
    Shop #: WSC 05124
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 160608 054 0402
    Coding: 00733421
    Shop #: WSC 05124
    2 Faults Found:
    01502 - Bulb for Rear Fog; Left (L46)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 19
    Mileage: 129961 km
    Time Indication: 0
    Date: 2021.12.29
    Time: 03:44:00
    Freeze Frame:
    ON
    Voltage: 12.70 V
    ON
    ON
    OFF
    OFF
    OFF
    01519 - Bulb for Back-Up Lights; Right (M17)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 19
    Mileage: 129961 km
    Time Indication: 0
    Date: 2021.12.29
    Time: 03:44:00
    Freeze Frame:
    ON
    Voltage: 12.70 V
    ON
    ON
    OFF
    OFF
    OFF
    Mar 2022
    Hamilton
    Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
    Part No SW: 3C8 919 475 HW: 3C8 919 475
    Component: PARKHILFE 8K H07 0007
    Revision: -------- Serial number: 97530815900374
    Coding: 300103
    Shop #: WSC 05314 000 00000
    VCID: 71BFDEAB31A049B370D-8024
    Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
    Part No SW: 3C0 907 376 HW: 3C0 907 376
    Component: DAEMPFUNGS-SG H07 0069
    Revision: 00000000 Serial number: 28050800920003
    Coding: 010180
    VCID: 6695BDF7086E9E0B15F-8032
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 HW: 5N0 959 655
    Component: J234__016 VW10 HI 1815
    Revision: 19013000 Serial number: 0039BPAPBRNF
    Coding: 0012598
    VCID: 7AADF98760D60AEBC17-802E
    Subsystem 1 - Serial number: 6333FTS623821338
    Subsystem 2 - Serial number: 6343FTS653181418
    Subsystem 3 - Serial number: 6353ETS6QD11TVNP
    Subsystem 4 - Serial number: 6363ETS69GLKTVNP
    Subsystem 5 - Serial number: 00000000000000000
    Subsystem 6 - Serial number: 00000000000000000
    Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
    Part No SW: 3C0 953 549 AC HW: 3C0 953 549 AC
    Component: J0527 0020
    Revision: 00026000 Serial number: 3C9953507AR
    Coding: 0001212
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
    Part No SW: 3C0 920 871 H HW: 3C0 920 871 H
    Component: KOMBIINSTRUMENT VD1 2416
    Revision: V0002000 Serial number: 00000000000000
    Coding: 0007505
    Shop #: WSC 04963 002 1048576
    VCID: 290FF6CBD5F07173F8D-807C
    Address 19: CAN Gateway Labels:. 3C0-907-530-V2.clb
    Part No SW: 3C0 907 530 H HW: 3C0 907 951
    Component: J533__Gateway
    ' 0142
    Revision:
    ' Serial number: 2600P085270168
    Coding: FDABFF06C04612F100
    Shop #: WSC 73020 981 58226
    VCID: 2615FDF7C4EE5E0BD5F-8072
    2 Faults Found:
    01305 - Databus for Infotainment
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 17
    Mileage: 129961 km
    Time Indication: 0
    Date: 2021.12.29
    Time: 03:26:23
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 17
    Mileage: 129961 km
    Time Indication: 0
    Date: 2021.12.29
    Time: 03:27:07
    Address 22: AWD Labels: None
    Part No SW: 0BS 907 554 HW: 0BS 907 554
    Component: Haldex 4Motion 4011
    Coding: 0000005
    VCID: 03538463171C4B23921-8056
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 S HW: 3C0 959 433 S
    Component: IMMO 041 0383
    Revision: 00041000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    VCID: 3A2D39872056CAEB817-806E
    Subsystem 1 - Part No: 3C0 905 861 G
    Component: ELV 027 0380
    3C0905861G ELV 027 0380
    Address 2E: Media Player 3
    Cannot be reached
    Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
    Part No SW: 3C0 959 760 E HW: 3C0 959 760 E
    Component: Sitzverstellung 1101
    Revision: 00005000 Serial number: 00000000000000
    VCID: 2F3B18D3EB141F43269-807A
    Address 37: Navigation
    Cannot be reached
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
    Part No SW: 1K0 959 701 AE HW: 1K0 959 793 P
    Component: J386 TUER-SG FT 1518
    Revision: 71009005 Serial number: 00000539188529
    Coding: 0005047
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 1K0 909 144 E
    Component: EPS_ZFLS Kl. 209 2501
    Revision: 00H15000
    Shop #: WSC 17380 143 30549
    VCID: 2C010FDFDA02645B03B-8078
    Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
    Component: KSG PQ46 ELV 041 0472
    Coding: 0091020051030E76300494157008DFCE707801
    Subsystem 1 - Component: Sounder No Answer
    Subsystem 2 - Part No: 3C0 951 171 C
    Component: Neigungssensor 004 0611
    Subsystem 3 - Part No: 3C0 951 171 C
    Component: Innenraumueberw.004 0611
    1 Fault Found:
    01134 - Alarm Horn (H12)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 18
    Mileage: 129961 km
    Time Indication: 0
    Date: 2021.12.29
    Time: 03:44:11
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
    Part No SW: 1K0 959 702 AE HW: 1K0 959 792 P
    Component: J387 TUER-SG BT 1518
    Revision: 71009005 Serial number: 00000064688525
    Coding: 0005046
    VCID: 72BDD1A738A672AB897-8026
    Address 53: Parking Brake Labels: 5N0-907-801.clb
    Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
    Component: J540 EPB3 VW-10498 0003
    Revision: 008 Serial number: 00000000040116
    Coding: 0000057
    Shop #: WSC 05311 000 08193
    VCID: 2809F3CFCEFA487BE73-807C
    Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
    Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
    Component: AFS-Steuergeraet 0133
    Revision: 00H04000 Serial number:
    Coding: 2346241
    VCID: 343117BF02323C9B5BB-8060
    Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
    Component: AFS-Lst.-Modul l 0004
    Coding: 00000035
    Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
    Component: AFS-Lst.-Modul r 0004
    Coding: 00000035
    Address 56: Radio
    Cannot be reached
    Address 57: TV Tuner
    Cannot be reached
    Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
    Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
    Component: J388 TUER-SG HL 0307
    Revision: 41004101 Serial number: 00000000439021
    Coding: 0000144
    VCID: 70B9DBAF36AA40BB7F3-8024
    Address 6C: Back-up Cam.
    Cannot be reached
    Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
    Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
    Component: J389 TUER-SG HR 0307
    Revision: 41004101 Serial number: 00000000446210
    Coding: 0000144
    Address 77: Telephone
    Cannot be reached
    End----------(Elapsed Time: 03:11, VBatt start/end: 13.3V/13.2V)-----------
    Mar 2022
    Hamilton
    hi here is the scan the two majors i need to resolve are the abs and reverse light and fog light
    That seems a bit unusual.
    The coding is correct.
    Try setting coding to 0000000, save, then cycle ign and set coding back to 0001439.
    For your rear lights they have an electrical fault. Start with fuses, globes.
    May 2023
    Indianapolis
    I advised contacting a licensed Volkswagen dealership or a skilled auto mechanic when trying to get a code for the ABS module. They will have access to the equipment and materials needed to find the proper coding for your ABS module.
    Oct 2017
    VIC
    Quote Originally Posted by Imaduck View Post
    HELP PLEASE
    When you get a chance have a read of this post:
    Replacing rear brake pads causes EPB fault (vwwatercooled.com.au)
    perhaps you might find something useful there.
    2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 398K ... and still going
