Results 1 to 10 of 10
Thread: 01134 Alarm horn no signal
    Dec 2014
    UPDATE: I finally got an opportunity on a day without rain to remove the alarm horn. Here are some notes for anyone else who has to tackle this job. I read somewhere that the bracket is held to the body with rivets. So I drilled what I thought was the head of the ‘rivet’. This took quite some time.
    01134 Alarm horn no signal-img_4750-jpg
    Once I’d done this, I discovered that in fact there are two captive nuts attached to the car body. The alarm is held on by two bolts that have no hex or slot on the head. These bolts were held in place by a lot of blue thread sealant.
    01134 Alarm horn no signal-img_4755-jpg
    If I knew these were bolts before I started, I might have tried to cut a slot in the head of the bolt to unscrew it. Once the bracket is off the car, the alarm can be removed from the bracket.
    01134 Alarm horn no signal-img_4754-jpg
    I’d already decided to source another alarm, so it was a one minute job to cut it open with a Dremel tool.
    01134 Alarm horn no signal-img_4756-jpg
    Mine was as described by h100vw. The Ni-MH battery had leaked and corroded a lot of the circuit board.
    01134 Alarm horn no signal-img_4757-jpg
    01134 Alarm horn no signal-img_4758-jpg
    The captive nuts will make it easy to reattach the bracket.
    2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
    Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
