My car is a red colour and bit of the red have chipped off as spots and what not showing a white (base coat?) underneath.
What's the best way to remedy this?
Also, some of the white spots have also chipped exposing what I assume is metal.
Past - '95 VW Golf MK3 VR6
bump for this.
call the dealership and order a bottle. $20.00
any alternatives?
I slowly fill the chip with paint and rub back with 3000 wet paper. Keep the sanding close to the chip when it is good, give it a rub with some scratch-X or similar cutting polish. If you are repairing a metallic paint, mix a solution of clear and colour. You may need to do this a few times before you polish the repair.
08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
http://photobucket.com/gregsr32
cheers for that.
got the nail polish style bottles from vw, instructions are in german but I imagine one's a primer (clear) and the other is the paint (green bottle). prime a layer, paint a layer, dry, paint a layer, dry, paint a layer, cut back.
this sound good greg?
The kit from VW is actually paint and clear coat, not primer.
White Scirocco R
White MK3 Golf 2dr
White Caddy (Work Van)
