Results 1 to 5 of 5
Thread: Bike ITB info
    Bike ITB info
    Copied from another site.
    Lot's of good info.
    SUZUKI
    Make/Model: GSXR600
    Year: -01
    Number of Tb:
    Inside Diameter: 38mm
    Center-Center (left to right from behind):
    Overall Length:
    Outside Diameter (intake):
    Outside Diameter (filter):
    Separate casting:
    Injector Make/Model:
    Flow Rate (45psi/100%):
    Fuel Rail Inside Diameter:
    Additional Info:
    Make/Model: GSXR 600
    Year: -02
    Number of Tb: 4
    Center-Center (left to right from behind): 80-80-80mm
    Overall Length: 83mm
    Outside Diameter (intake): 44mm
    Outside Diameter (filter): 45mm
    Separate casting: Yes
    Injector Make/Model: Keihin KN4, 0J07 AAA A
    Flow Rate (45psi/100%): 240cc/min?, 13Ω
    Fuel Rail: Alu casted, Inside diameter 6mm (9mm in the ends)
    Additional Info: sec. throttles controlled by ECU.
    Make/Model: GSXR 750
    Year: -98, -99
    Number of Tb: 4
    Inside Diameter: 46mm
    Overall Length: 91mm
    Outside Diameter (intake): 54mm
    Outside Diameter (filter): 54mm
    Injector Make/Model: Keihin,
    Additional Info: No sec. throttles.
    Year: 2002
    Number of Tb: 4
    Inside Diameter: 42mm
    Center-Center: 80mm
    Overall Length: ???
    Outside Diameter (intake): 48mm
    Outside Diameter (filter): 52mm
    Fuel Rail Inside Diameter: 2.4mm
    Make/Model: GSXR750
    Year: -06
    Number of Tb:
    Inside Diameter: 40mm
    Overall Length:
    Separate casting:
    Additional Info:
    Make/Model: DL1000 V-Storm
    Year: ?
    Number of Tb: 2
    Inside Diameter: 45mm
    Overall Length:
    Separate casting:
    Additional Info: dual throttle plate
    Make/Model: GSXR 1000
    Year: -02
    Number of Tb: 2
    Overall Length:
    Separate casting: No (dual Tbīs)
    Flow Rate (45psi/100%): 230cc/min
    Make/Model: GSXR1000
    Year: -03
    Number of Tb:
    Overall Length:
    Separate casting:
    Additional Info:
    Year: -03
    Number of Tb: 4
    Inside Diameter: Tapers from 50 to 42mm
    Overall Length: 90mm
    Outside Diameter (filter): 53mm
    Additional Info: Pic without secondary butterflies and fuel rail.
    Make/Model: GSXR 1300 (Busa)
    Year: 1999-2003
    Number of Tb: 4
    Overall Length:
    Additional Info:
    Year: pre 2002 ?
    Number of Tb: 4
    Inside Diameter: 42mm at injector end, tappered from 51mm at air horn end
    Outside Diameter (intake): 55mm
    Flow Rate (45psi/100%): ?
    Fuel Rail Inside Diameter: PA66-G35
    Additional Info: no secondary butterfly
    KAWASAKI
    Make/Model: ZX6R
    Year: -02
    Number of Tb:
    Overall Length:
    Separate casting:
    Fuel Rail:
    Additional Info:
    Make/Model: ZX6R 636 B1
    Year: 2003
    Number of Tb: 2
    Center-Center (left to right from behind): 75-75-75mm
    Outside Diameter (intake): 52,6mm
    Outside Diameter (filter): 50,8mm
    Injector Make/Model: BOSCH 280031V
    Flow Rate (45psi/100%): 245cc/min
    Additional Info:
    Make/Model: ZX6R
    Year: -05
    Number of Tb: 4
    Overall Length:
    Separate casting:
    Fuel Rail:
    Additional Info: Oval TBīs
    Make/Model: GPZ750 Turbo
    Year:
    Number of Tb:
    Inside Diameter: 34mm
    Overall Length:
    Separate casting:
    Additional Info:
    Make/Model: Z1000
    Year:
    Number of Tb:
    Inside Diameter:
    Overall Length:
    Separate casting:
    Additional Info:
    Make/Model: ZX10
    Year: -04
    Number of Tb:
    Inside Diameter: 43mm
    Overall Length:
    Separate casting:
    Fuel Rail:
    Additional Info:
    Make/Model: GPZ1100
    Year: 1981-1982
    Number of Tb: 4
    Center-Center (left to right from behind): 77-97-77mm
    Overall Length:
    Outside Diameter (intake): 40mm ("serrated")
    Outside Diameter (filter): 40mm ("olived")
    Flow Rate (36psi/100%): 180-200cc/min, 2,5Ω
    Additional Info: Picture is from a -82
    Make/Model: GPZ1100
    Year: 1983-1984
    Number of Tb: 4
    Inside Diameter: 35mm
    Overall Length:
    Additional Info:
    Make/Model: ZX12
    Year: 2002-2003
    Number of Tb: 4
    Overall Length:
    Separate casting:
    Fuel Rail:
    Additional Info: vier pintle injectors tot 190pk ?
    YAMAHA
    Make/Model: R6
    Year: -03
    Number of Tb:
    Overall Length:
    Separate casting:
    Fuel Rail:
    Additional Info:
    Make/Model: YZF-R6
    Year: 2003-2004
    Number of Tb: 4
    Center-Center (left to right from behind): 72.5-72.5-72.5mm
    Overall Length: 95mm
    Outside Diameter (intake): 52mm
    Outside Diameter (filter): 44mm
    Separate casting: Not exactly, but can be cut apart easily (fuel rail)
    Injector Make/Model: Nipon, # 250031F
    Flow Rate (??? psi/100%): ??? cc/min, 11.7Ω , 12mH
    Injector Make/Model: Nipon, # 2500322, type: INP250/4
    Flow Rate (??? psi/100%): ??? cc/min, ??? Ω
    Additional Info:
    Make/Model: R6
    Year: -03
    Number of Tb:
    Overall Length:
    Separate casting:
    Fuel Rail:
    Additional Info:
    Make/Model: R6
    Year: -05
    Number of Tb:
    Overall Length:
    Separate casting:
    Fuel Rail:
    Additional Info:
    Make/Model: YZF R1
    Year: -04
    Number of Tb: 4
    Overall Length:
    Separate casting:
    Fuel Rail:
    Additional Info: Primary and secondary butterfly valves, longnose 4 pintle
    Make/Model: R1
    Year: -04
    Number of Tb: 2
    Center-Center (left to right from behind): 78-78-78mm
    Overall Length:
    Additional Info:
    Make/Model: YAMAHA FJ1300
    Year: 2003-2006 (US) 2001 up others
    Number of Tb: 4
    Center-Center (left to right from behind): 77-87.5-77mm
    Outside Diameter (filter): 46mm
    Injector Make/Model: Keihin ??
    Flow Rate:
    Other: TB made by mikuni, uses a coolant thermowax type warmup system for high idle, no secondairy throttle. This model has 150 BHP and 99 TQ.
    HONDA
    Make/Model: CBR F4i
    Year:
    Number of Tb:
    Inside Diameter:
    Overall Length:
    Separate casting:
    Additional Info:
    Make/Model: RC51
    Year: 2000
    Number of Tb: 2, 2 injectors per TB
    Inside Diameter: 48mm
    Center-Center (left to right from behind): 24mm (TB's are not parallel)
    Overall Length: approx 40mm
    Outside Diameter (intake): 60mm
    Outside Diameter (filter): 70mm (not sure how filter fits)
    Separate casting: Yes, independent TB's, mounted to linkage bracket. Modification needed of fuel pipe and linkages to change spacing.
    Injector Make/Model: ????/????
    Flow Rate (XXpsi/100%): XXXcc/min, approx 11Ω , ??mH
    Fuel Rail: Alu casted, 1 per injector, joined by solid fuel lines
    Additional Info: Has a manual choke mechanism synchronized to both TBs.
    Make/Model: CBR600
    Year: -03
    Number of Tb:
    Overall Length:
    Separate casting:
    Additional Info:
    Make/Model: CBR600RR3
    Year:
    Number of Tb: 2
    Inside Diameter: 37mm
    Overall Length:
    Separate casting:
    Additional Info: Injectors mounted in cylinderhead.
    Make/Model: CBR600FSi
    Year:
    Number of Tb: 2
    Inside Diameter: 36mm
    Overall Length:
    Separate casting: No (dual Tbī)
    Additional Info:
    Make/Model: CBR 929
    Year:
    Number of Tb: 4
    Center-Center (left to right from behind): 80mm-80mm-80mm
    Overall Length of casting 70mm
    Outside Diameter (intake): 49mm
    Outside Diameter (filter): - flat flange for airbox
    Separate casting: 2 twin body castings
    Injector Make/Model: ?? Marked as OK24 B
    Flow Rate (45psi/100%): not sure. RUns at 50psi
    Additional Info: produces 150bhp at 11,500rpm from 74x54 929cc. 11:3.1 comp ratio, 10 litre airbox.
    Make/Model: CBR900 954 Fireblade
    Year: 2003
    Number of Tb: 2
    Inside Diameter: Tapers from 45-41mm
    Overall Length: 77mm
    Outside Diameter (intake): 50mm
    Injector Make/Model: Denso 12 226 4490 I suspect the 226 is cc/min, as the bike is good for 150hp... 13.3 ohms
    Flow Rate (45psi/100%): ?? (Std fuel pressure on bike is 50psi)
    Additional Info: Factory couplers need to be used as inside diameter is offset and not a perfect circle.
    Make/Model: CBR1000
    Year: -04
    Number of Tb: 4
    Overall Length:
    Separate casting:
    Flow Rate (45psi/100%): 240-260cc/min at 43psi (unconfirmed)
    Additional Info:
    Make/Model: CBR1000
    Year: -06
    Number of Tb: 4
    Inside Diameter: 44mm
    Overall Length:
    Separate casting:
    Additional Info:
    Make/Model: CBR 1100 Blackbird
    Year: ??
    Number of Tb: 2
    Center-Center (left to right from behind): 85-85-85mm
    Overall Length:
    Flow Rate (43psi/100%): ~335cc/min, 13Ω
    Additional Info:
    APRILLIA
    Make/Model: RSV mille
    Year: -02
    Number of Tb: 2
    Inside Diameter: 51mm
    Overall Length:
    Separate casting:
    Additional Info:
    DUCATI
    Make/Model: MONSTER 620ie
    Year: -02
    Number of Tb: 2
    Overall Length:
    Separate casting:
    Additional Info:
    Make/Model: TWIN VALVE 620, 800-1000
    Year: -02
    Number of Tb: 2
    Overall Length:
    Separate casting:
    Additional Info:
    Make/Model: S2R 1000
    Year: -05
    Number of Tb: 2
    Overall Length:
    Separate casting:
    Additional Info:
    Make/Model: ST3, ST4
    Year: -02
    Number of Tb: 2
    Inside Diameter: 50mm
    Overall Length:
    Separate casting:
    Additional Info:
    TRIUMPH
    Make/Model: DAYTONA 995i
    Year: ?
    Number of Tb: 3
    Overall Length:
    Separate casting:
    Additional Info:
    SNOW-MOBILE
    ARCTIC CAT
    Make/Model: ZR600 Snowmobile
    Year: 1998
    Number of Tb: 2
    Center-Center (left to right from behind): 134.5
    Overall Length: 105mm
    Flow Rate (XXpsi/100%): XXXcc/min, 2.9Ω , 5.8mH
    Additional Info: 2-stroke snowmobile, parallel twin 600cc, 105hp
    CAR
    BMW
    Make/Model: M3 e30
    Year: ?
    Number of Tb: 4
    Overall Length:
    Separate casting:
    Fuel Rail:
    Additional Info:
    Modified Tbīs
    Suzuki GSXR600-02 on Kawasaki GPZ900R -88 (by Marcus)
    Suzuki GSXR750 98-99 on Ford 2.3 litre Escort RS2000 (by Exupturbo)
    Suzuki GSXR750 98-99 on Yamaha ZXR1000 Turbo (by Exupturbo)
    Kawasaki GPZ1100-82 on Ford 1600CVH (by philhoward)
    Suzuki GSXR1000 on ST170 Manifold (by Asad)
    Honda CB919 on Imp (by Rootes)
    [/quote]
    there is a few threads on clubgti.com about 16v running bike iTB...i will did out the links when i have 5
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
