Page 1 of 9 123 ... LastLast
Results 1 to 10 of 85
Thread: building a 2L 8v for turbo?
    how many parts are out there for the 1.8 and 2L 8v engines that were in the mk3 Golf for building them for forced induction?!
    -low com pistons
    -lower compression
    -custom manifold
    -custom exhaust manifold
    -ecu?
    not being built for 200hp, something around the 180hp mark could easily be achievable in a reliable drivable set up i think.
    any ideas here
    Jun 2007
    Eastern Suburbs Melbourne
    josh.. what are you thinking???
    maybe a 1.8 with a 2.0 head? would this lower the comp? Prolly have to custom the manifolds, and don't know anything about the ecu; maybe run K-Jet or something mechanical?
    i like volkswagens
    Aug 2006
    Melbourne VIC
    Mate its all custom made by local machine shops... I spose u could get stuff from overseas but go local and get the rite stuff made... Cost just as much...
    BTW my ol man keep blowing heads of ol skool 8v's so take it easy
    Jan 2007
    well... the stock internals are rated fairly well. Pistons won't be necessary if you get a low compression ratio gasket, then you can run 200 hp at the wheels for no worries
    Heres a site that sells a kit, its all pretty bloody interesting stuff if you ask me.
    http://www.kineticmotorsport.com/pro...1-468-136.html
    Found a 2.8l 24v VR6 450hp kit the other day for 5000 grand... that wasn't bad lol!
    Plenty of folk have done DIY turbo stuff on vwvortex.com have a look in the forced induction thread.
    A couple of stacked G60 head gaskets is a pretty std way to decrease compression.
    Aug 2005
    It's pretty cheap and easy to do it simply. 220-250hp with a T3 super60 without silly boost. More parts around than you can poke a stick at aswell
    Jan 2007
    yeah exactly best place to start and to make a list of all the items you need. Low comp gaskets are cheap though 150 posted, thats not bad really....
    Tuning would be the biggest pain though... But all car chips are flashable, just a matter of finding the right person with the right level of expertise.
    Jan 2008
    Seemingly people on these forums always use chips or flash their ecu's... coming from imports and such... is there a disadvantage with these cars to use systems such as microtech, wolf, ems, haltec, etc?
    You should be able to run low boost (4psi low) through a stock motor even. not massive gains, most likely just a better power band.
    If i were to consider this, i'd just get the 1.8 turbo motor and bore it out if you want bigger displacement, or possibly use it's head. I am not familiar with the specs of these engines, but the 8V sohc head more than likely would not flow as much as the 1.8 DOHC head, and when it comes to performance, rule of thumb is that flow = power. Then the issue with the compression is easily resolved with either the use of multiple or a thick hed gasket, or else custom pistons - which you may need to get anyways due to how rare parts for these cars seem to be (to me anyways).
    Custom manifolds are big $$$; you may be best off seeing how well a ported stock manifold may work/their restrictions, or how much stock items flow before they restrict power.
    Nov 2005
    k-jet is the worst idea for turbo charging do not do it
    wabit
    Feb 2007
    I spoke to a guy from malta who had a 1.8 8v mk2 turbo 250hp.
    He said it was easy, most expensive thing was the custom piping and exhaust.
    He had a stand alone management, DTA or something like that, a desel gasket to lower compression and was running a K04 turbo. Cant remember how much PSI. He said all together with full custom stainless steal exhaust it was 6000 euros.
    If you like i can dig up his email address. His car was on VWFixx, still there in the arcives i think.
    MK1 GLS 3door
    A4 B7 2.0T
