Originally Posted by
isaacinsoll
Could I use an OBDeleven device to set up pace car indicators on my golf 7 r? Seems like the cheaper way rather than buying a Ross tech cable
Isaac: Hello. The short answer is YES!
OBD11 has a slightly different protocol, but the VCDS instructions are translatable to ODB11-speak. The major difference in ODB11"s language is that the adaptation channels are presented to the user in Parent-Child format whereas VCDS has a flat presentation structure. I personally find the OBD11 format to be more intuitive - and I suspect that in the near future VCDS will do the same.
So to access a particular adaptation channel with OBD11, you will first need to identify the Parent-root and then a second screen identifies the children adaptation channels. This means that there are no parentheses used in any adaption channels with OB11 (as is the case with VCDS).
And yes, it's a much cheaper alternative - but you will need an Android tablet/mobile phone and you will need good internet service at the place of use! The other good feature of OBD11 for newbies is their Apps. These are one-click facilities for implementing those more complex tweaks. They generally cost 10 credits per App, but for less experienced users, they are a good, easy way to make changes- great niche product (IMO)
But VCDS is a much more mature device and it's a more stable platform (IMO). The Lithuanians are still developing their OBD11 product, so it's unclear how future proof it will be
PS: I wrote a short product review about OBD11 on the mk7 forum- that you might find interesting
