Page 72 of 198 FirstFirst ... 2262707172737482122172 ... LastLast
Results 711 to 720 of 1974
  1. #711
    Hello Family!
    TPMS (Tire Pressure Meter System) para VW Golf MKVII
    TPMS VW Golf MKVII RLine 4Motion 1/2 - YouTube
    TPMS VW Golf MKVII RLine 4Motion 2/2 - YouTube
    Codificación Completa:
    Ingredientes Principales:
    Unos 300€ de inversión!
    - 5Q0 907 273 / 5Q0 907 273A -> Centralita TPMS
    - 8E0 971 934 A -> Conector Centralita TPMS
    - 5Q0 907 275 / 5Q0 907 275B -> 4 Válvulas TMPS
    - Cable
    - VAGCOM
    - VCP (opcional)
    Good Night!
  2. #712
    Nov 2014
    ACT
    VCDS (VAG-COM) codes and programmable options for Golf Mk7
    Quote Originally Posted by bobcrusader View Post
    My understanding is that EF should have higher priority than CD and AB. Swapping them doesn't explain why it works when set to 0
    Hi bobcrusader, what are the values for AB and CD channels? I remember long time back you mentioned both of them were set to 127 in dimmwert and also I noticed when the AB is 127 it did not blink regardless where I kept blink code, don't know why. Please check the full sets for 2SL and 3SL
    Forgive my ignorance, I believe you wanted to dim the DRL U LED outer when the blinker is ON.
    Regards,
    MRG
    2015 Limestone grey Golf 103TSI Highline with Luxury pack and Driver Assistance Pack II
    2012 Pantom Black Audi Q5 3.0 TDI with B&O sound system
  3. #713
    Quote Originally Posted by XaGiCo View Post
    Hello Family!
    Good Night!
    XaGiCo: Gracias por la reseña - interesante
  4. #714
    May 2014
    Russia
    XaGiCo
    Hello, I retrofit it too =)
    do u have this menu? (Choose tire type)
    Attached Thumbnails Attached Thumbnails VCDS (VAG-COM) codes and programmable options for Golf Mk7-a6a2dbas-960-jpg
  5. #715
    bobcrusader Guest
    Correct 127 all around at first. I did drop the CD to 80, as it was very bright at night. Let me drop AB down to 100 and see if it works.
  6. #716
    Hi @DV52
    You're Welcome Don !!!
    Regards
    XaGiCo
  7. #717
    Quote Originally Posted by zloybob View Post
    XaGiCo
    Hi @zloybob
    I do not see that screen!
    you can help!
    you can skip coding?
    Thanks !!'
    Regards
    XaGiCo
  8. #718
    May 2014
    Russia
    XaGiCo,
    In your video the item Standard and its not work for you?
    Its not coding. Its edited manually zdc.
  9. #719
    XaGiCo,
    Hi @zloybob
    Look long version of the video.
    That has the file name ZDC you used?
    Thank you.
    https://vimeo.com/155364520/
  10. #720
    May 2014
    Russia
    Hi @zloybob
    Thank you.
    Do u have skype or whatsapp? Pm me) its selfmade "zdc"
