Page 34 of 198 FirstFirst ... 2432333435364484134 ... LastLast
Results 331 to 340 of 1974
  1. #331
    ^^^^ See response to Jonoz question in thread "Disable Stop/start - VCDS tweak" here
  2. #332
    Feb 2008
    Thanks alanzidane for bringing this all together,
    Has anyone found the coding for this one? I'm keen to try it.
    Cheers!
    Quote Originally Posted by alanzidane View Post
    9. Full brake light if you have LED tail light(GTI Performance OR R)
    I lost the screen shot to show your guys. Here is the photos to compare before and after. I'll post the screen shot later on.
    CR Audi RS3
    PW Golf 7 GTI
  3. #333
    Mar 2009
    Is there a way to program the indicators to flash four times instead of three for when you tap the stalk?
  4. #334
    Quote Originally Posted by Ralfi View Post
    Ralfi: yes, my VCDS tweak instructions are HERE
  5. #335
    Apr 2014
    Albany Creek, Qld
    Quote Originally Posted by 2muchcoffeeman View Post
    Cheers!
    2MuchCoffeeMan do you mean this? (for the inner tail lights to work as brake lights as well)
    Activation of the tail light brake light
    The inner taillights are also activated during braking.
    1. Select STG 09 (vehicle power)
    2. STG Security Function 16
    3. Enter access code 31347
    4. Channel (8 )-Leuchte27 NSL RC6-Lichtfunktion C27
    5. Set to brake light - Bremslicht (default: nicht aktiv)
    6. Channel (10)-Leuchte27 NSL RC6-Dimming CD27
    7. Set to 100 Set(default: 0)
  6. #336
    Feb 2008
    Quote Originally Posted by TJG View Post
    Perfect! Many thanks!
    CR Audi RS3
    PW Golf 7 GTI
  7. #337
    Feb 2008
    I found this one on another forum. Sounds like it might work as well?
    9- Central Electronics
    16- Security Access
    10- Adaptations
    Left Inner Tail light functions as runner/brake/ signal.
    8 leuchte23sl HLC10-Lichtfunktion C23
    Brake Light
    9 leuchte23 sl hlc10 - Lichtfunction D 23
    Blinken Links Hellphase
    10 leuchte23sl hcl10 - dimmwert CD 23
    100
    Allows Left Signal to "overpower" Running light and brake Light.
    12 leuchte23sl hlc10-lichtfunktion E 23
    Blinken Links Dunkelphase
    14 leuchte23sl hcl10-dimmwert EF 23
    0
    15 leuchte23sl hlc10-dimming direction EF 23
    Minimize
    Right Inner Tail light functions as runner/brake/ signal
    8 leuchte24sl HRA65-Lichtfunktion C24
    Brake Light
    9 leuchte24sl HRA65 - Lichtfunction D 24
    Blinken Rechts Hellphase
    10 leuchte24sl HRA65 - dimmwert CD 24
    100
    Allows Right Signal to "overpower" Running light and brake Light.
    12 leuchte24sl HRA65-lichtfunktion E 24
    Blinken Rechts Dunkelphase
    14 leuchte24sl HRA65-dimmwert EF 24
    0
    15-Leuchte24SL HRA65-Dimming Direction EF 24
    Minimize
    Left Signal completely goes out between blinks.
    16 - leuchte20BR LA71-Lichtefunktion G 20
    19 - leuchte20BR LA71-dimming Direction GH 20
    Minimize
    Right Signal completely goes out between blinks.
    16 - leuchte21BR RC8-Lichtefunktion G 21
    19 - leuchte21BR RC8-dimming Direction GH 21
    Minimize
    CR Audi RS3
    PW Golf 7 GTI
  8. #338
    Mar 2011
    Anyone in Brisbane with a VCDS that can help me turn down my soundaktor? I'm on the north side at alderley but happy to drive to you. Cheers!
  9. #339
    Apr 2014
    Albany Creek, Qld
    Quote Originally Posted by Boon View Post
    Can Do (Albany Creek) - PM me if your interested.
  10. #340
    Apr 2014
    Albany Creek, Qld
    16- Security Access
    10- Adaptations
    Brake Light
    100
    0
    Minimize
    Brake Light
    100
    0
    Minimize
    Minimize
    Minimize
    Think this might be for US where they can use brake lights also as indicators. Looks like this might blink your brake/tail lights with your indicators. Not really sure though.
