Originally Posted by
lunchboxGTI
Thanks, I knew about the 0.0 method but was trying to set it to the right km for him. That link explains how to so again thanks.
Lunchbox:
If you want to get "more creative" and you want to fiddle with stuff like max/min settings (as you mentioned in your first post), then here are the other settings for the SRI
The RT instructions place a "0" in the setting in adaptation channels with ID #5 and ID# 9 (the values in my pic are my current values). I've not played with the Max/Min values, but I suspect that the "FIX" channels are the ones to change and the ESI channels reflect the values in the FIX channels. Let me know if I'm correct-please
To access these channels just use the pull down menu in 10-adaptation for control module 17-Instruments.
Enjoy!
