Page 14 of 198 FirstFirst ... 412131415162464114 ... LastLast
Results 131 to 140 of 1974
  1. #131
    May 2014
    Russia
    how the long coding string from my car could be used for his Discover Pro screen. I would have thought that a byte-by-byte comparison of the coding for the two MMIs would be unworkable. Any ideas ?
    your coding
    02730008FF00000011510001000900001F0100960100010247
    my coding
    02730001FF00000011110001001900001F0100960100010077
    changing 19 to 09 activated hidden menu items, but value in adaptations 1024 dont work for Russia =(
    btw
    changing 01 to 02 will switch skin to GTI look
    VCDS (VAG-COM) codes and programmable options for Golf Mk7-8be9594s-960-jpg
  2. #132
    Aug 2011
    Quote Originally Posted by zloybob View Post
    your coding
    my coding
    btw
    1024 is the key for Australia only. Is the option to turn on TP disabled or is it just that you're getting zero messages? If the TMC service in Russia isn't free then there's not much you can do without it appearing in new Golfs/Octavias
  3. #133
    your coding
    my coding
    btw
    Zloybob: Sorry that the coding changes didn't work for you. If you need any more coding strings, just PM me. Given readerr0r's advice, the magic number for enabling TMC in Russia is probably different. As I have said in a previous post, "1024" is equivalent to Hexadecimal "400". If there is any consistency accross countries, this may provide a clue (but I admit that it's not much of a clue) - Good luck.
    Thanks for the Skin switch tweak. I saw a similar tweak on stemei.de site. Instructions were:
    Adaptation of the Background of the MFA to Carbon Look
    1. STG-17 (Instruments)
    2. 10 Adaptation
    3. Select "Displaydarstellung" channel (which means "Display representation" in English)
    4. Change new value to "version 2"
    Haven't tried this tweak yet.
  4. #134
    May 2014
    Russia
    Quote Originally Posted by readerr0r View Post
    zero messages, btw default value in adaptation was 16
    Zloybob: Sorry that the coding changes didn't work for you. If you need any more coding strings, just PM me. Thanks for the Skin switch tweak. I'll try it out in the next few days.
    its working, and now i can enable TP, AF, RDS, thnx =)
    one more tweak for 5F
    change byte 18 value 00 to 03
    and u get mini GTI =)
    VCDS (VAG-COM) codes and programmable options for Golf Mk7-cbe9594s-960-jpg
  5. #135
    Zloybob: Well done- you are a Russian Genius!!
    Btw - is the Temp on your pic correct -0.5 Deg C? That's cold!!
  6. #136
    Apr 2014
    Melbourne, VIC
    Now that i finally have my R, am wanting to make some changes given that the dealership wouldn't do it upon delivery.
    Namely the traffic one. Cant believe the dealership wouldn't do this.
    Also the brake lights and number plate lights.
    Anyone in Melbourne (pref Eastern Suburbs) able to assist??
    Sure I rustle up some beers etc for the effort.
    Thanks heaps in advance.
    Cheers,
    Blabba.
  7. #137
    Nov 2009
    Quote Originally Posted by Blabba View Post
    VAG-COM scanning, who can help
  8. #138
    May 2014
    melbourne
    Flying completly blind here...... spotted this on Ozbargain....does this deal represent any value or usefullness?
    Wholesale VAG COM 12.10.3 VAGCOM VCDS 12.10.30 Diagnostic Cable HEX USB Interface for VW Audi
    What software would I need to start tinkering?
  9. #139
    Dec 2009
    Kew, VIC
    This is a very suss looking device, and you should be aware that the software quoted appears to be Rosstech's latest version and quite definitely not legal.
    Buy at your own risk (but then, you're not risking much, I doubt Rosstech would sue you...)
  10. #140
    May 2014
    melbourne
    Quote Originally Posted by Idle View Post
    Thanks for the tip... think ill leave it Just spotted it and thought... hrmmm that seems cheap !
