Page 176 of 198 FirstFirst ... 76126166174175176177178186 ... LastLast
Results 1,751 to 1,760 of 1974
  1. #1751
    ^^^Fashionci:thanks for the kind words - but as you can see from my attributions in the VCDS reference thread, many tweaks are authored by other colleagues (so the thread content is really a forum community exercise)
    OK - as to your not so "odd idea", I don't have a definitive answer because I don't know what model car you drive, or the country of sale (where is "Mel, QL"?). However, at least for mk7s, the problem is that the Front-Field-Lights on the wing mirrors are connected to the driver & passenger side door control modules (@ address hex42 and hex52).
    From memory, I don't recall that there are any physical wire connections between the door modules and the BCM (@ address hex09) - notwithstanding that the BCM does control car locking (so the BCM is wired to the door locks, sill lights etc). This means that the only way to get the reversing signal to the door control modules is via a CAN message - but again for mk7s down here in the Antipodes, there are no Leuchte-sets in either the driver, or passenger door modules to receive this message. So alas, I don't think the tweak is possible.
    One of my tweaks on the VCDS thread is to co-opt the high level Brake light as a reversing light. I found that using the 3rd Brake light when reversing provided extra "general illumination" - which helped when backing the vehicle,.
    The other way of achieving (at least in part) illumination at the side of the vehicle is to switch-on the front fog lights when reversing. Fog lights (if fitted) have a wide lateral spread pattern that lights-up the side of the vehicle and they are used as static cornering lights for this reason.
    If you are using static AFS on your car - try changing IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt to the value,
    on in the BCM.
  2. #1752
    Mar 2020
    Mel, QL
    on in the BCM.
    Thanks my friend!
    After reading you answer, I can understand how the puddle lights work.
    Actually this idea came from one of my friend in China, they got some BYD(name of the brand) electic cars with this feature.
    Thanks again for the reply!
    I am now considering wiring the puddle lights with the front fog lights.VCDS (VAG-COM) codes and programmable options for Golf Mk7VCDS (VAG-COM) codes and programmable options for Golf Mk7VCDS (VAG-COM) codes and programmable options for Golf Mk7
    通过我的 SM-G9700 上的 Tapatalk发言
  3. #1753
    Pacific Paradise QLD
    Quote Originally Posted by fashionci View Post
    Thanks my friend!
    Be better to have them with the reversing lights wouldnt it as thats what you wanted them for
  4. #1754
    Mar 2020
    Mel, QL
    You can underatand my 'odd idea' betterVCDS (VAG-COM) codes and programmable options for Golf Mk7
  5. #1755
    Fasionci: hmm...... that's an interesting proposal!!
    Regardless of whether you use reverse lights, or fog lights and if you just connect the lamp wires together to achieve parallel operation - I make the following observations:
    • I'm not sure how the internal circuits inside the BCM and the Door modules will react if the module that isn't supplying current sees a back-fed 12V source from the module that is supplying the paralleled lights.
    • I'm almost certain that the Door control module won't like supplying extra electrical current to the (relatively) high wattage fog/reverse lamp - given that the internal ciruit for the pin on the door module is designed to run the low-current puddle light
    So. if you proceed and as a conservative design for your proposal, I suggest that you provide "blocking diodes" in the circuit (as in my picture).
  6. #1756
    Mar 2020
    Mel, QL
    Thanks for being so thoughtful!
    The circuit diagram really helps a lot!
    Now I am discussing it with my friend.
    We decide to use a 3-Terminal Voltage Regulator to maintain 12v within the puddle lights' circuit.
    But still there are some spec-details to test and decide, eg. the wiring route, the puddle-lights' max current, and others.
    After all, thanks again!
    I will update when the project is done.
  7. #1757
    Oct 2019
    Independence, MO
    This should be easier for you
    Enable Mirror LED Light for night parking*
    Module 09
    Security Access - 31347
    Adaptation
    Umfeldleuchte als Manoevrierleuchte
    Set to Active
    Module 6C
    Coding
    Manoeuvre_Light
    Enable
    *Viewable only with Area View system, see pic below showing illumination on the ground
    under the side view mirrors
  8. #1758
    Jul 2010
    Quote Originally Posted by SdvolksArteon View Post
    Module 09
    Adaptation
    Set to Active
    Module 6C
    Coding
    Manoeuvre_Light
    Enable
    i wonder if this will work with cars without the area view? i.e. puddle lights illumimate when reversing
    i had a look in my 09-electrics and "Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte" is currently set to "not active"
    i'll set this to active and see if it makes any difference.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  9. #1759
    I looked in my TIgs module and that isnt there so no go for us
  10. #1760
    Mar 2020
    Mel, QL
    Module 09
    Adaptation
    Set to Active
    Module 6C
    Coding
    Manoeuvre_Light
    Enable
    Thanks friend!
    I tried your method and finally it works!
    Awesome!!!
    Pic below is the result
