Did a few launches over the weekend and can report the counter does indeed increment:
http://www.vwwatercooled.com.au/foru...4DZALpng-1.jpg
Printable View
The happy maximum was 200
200 Launch Maximum Reached - Launch Control No Longer Functional
A mate with an S3 said he got an mild grilling at the Audi Centre when he recorded 16 in one year.
How to enable at the same time main beam/drl and fog lights for CH/LH?
Fog and DRL would look cool for CH/LH. I set mine to run the Fogs with DRL during the day. Fogs shut off at night when the mains come on. Can still use the switch to force the fogs on.
Looks cool, being LED the fogs are fairly dim during the day, but adds a nice subtle glow to the front grill.
Ok got both main beam and fog lights as CH/LH - I've set the coming home option to fog lights and manually used LC5 C6 and RB1 C7 to set them as CH/LH.
Anyone knows which channel is used for cornering lamps in headlights? I would like to set them as CH/LH too.
Hi, I have a problem on my golf 7 that I bought 2 days ago, and I found out that my high beam is not working, in my dashboard the blue indicator is lighting OK but no high beam, the car has factory Bi-Xenon and adaptive light with automatic high beam and also automatic light is not working.
I attach the scan of my car and I hope someone will help my, I think that is a problem from coding because the low beam is working ok.
Thank you!
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 55 5F 69 A5
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
Address 01: Engine (J623-CRBC) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 DT HW: 04L 907 309 D
Component: R4 2,0L EDC H22 5520
Revision: 83H22---
Coding: 111D0032047405082000
Shop #: WSC 00028 028 00075
ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
ROD: EV_ECM20TDI01104L906021DT_VW37.rod
VCID: 7AE3E533ACDFA05251A494D-802E
No fault code found.
Readiness: 0 0 0 0 0
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 L HW: 5Q0 937 086 L
Component: BCM PQ37BOSCH 020 0078
Revision: -------- Serial number: 86582709130972
Coding: 00021B46C2C122FB0BA44080B11C0708100A00000000000000 0000000000
Shop #: WSC 00028 028 00024
ASAM Dataset: EV_BodyContrModul1UDSBosc 011005
ROD: EV_BCMBOSCH_AU37.rod
VCID: 439D58D79B95219A42C2311-8016
Slave 1:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 130926 042 0551
Serial number: 130927211249
Coding: 0F4DDD
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M10D08H23M12S50S1
Coding: 00A8DD
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY132330SYY
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000027950607
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 A HW: 5Q0 919 298
Component: PARKHILFE PLA 011 0029
Revision: -------- Serial number: 61131326301384
Coding: 0031161151
ASAM Dataset: EV_EPHVA2CAU3700000 003014
ROD: EV_EPHVA2CAU3700000_VW37.rod
VCID: 3D692E2FFD71576A3406779-8068
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 A HW: 5Q0 907 572 A
Component: ACC Bosch MQB H04 0150
Serial number: 06101376510056
Coding: 001C1D00FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001013
ROD: EV_ACCMRRBoschVW372_AU37.rod
VCID: 3579360FC5418F2AFC769F9-8060
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 R HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0085
Revision: FF026026 Serial number: 20131003400224
Coding: 0C00
ASAM Dataset: EV_SMLSVALEOMQB 001011
ROD: EV_SMLSVALEOMQB.rod
VCID: 419152DF8189338A50EE1B9-8014
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 5G0 920 861 A HW: 5G0 920 861 A
Component: KOMBI 252 2210
Coding: 07A411086F94000801886A03040000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_AU37.rod
VCID: 2745EC470FEDEDBA7EEA651-8072
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 M
Component: GW MQB High 212 2147
Revision: -------- Serial number: 24091310801455
Coding: 030100340B087300EF00065E1C0F0001000100000000000000 0000000000
ASAM Dataset: EV_GatewConti 009011
ROD: EV_GatewConti.rod
VCID: 3B6D2037E365595A0A32591-806E
Alternator:
Multifunction unit control module:
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K
Component: E221__MFL-DC1 H15 0038
Serial number: 27130001561400033391
Coding: 2DFFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 2624821403
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 HW: 5Q4 959 593
Component: TSG FS 007 0006
Serial number: 0000076967124
Coding: 003A02208C00028000001000
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 02139DD3C40FE8920974CCD-8056
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000002923623
Coding: 010000
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 123 1043
Coding: 1303
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB.rod
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000077829631
Coding: 003A00208E00028000801000
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 011192DFC109F38A106EDB9-8054
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000002934697
Coding: 090000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Revision: -------- Serial number: --------------
Coding: 029A00104F000200
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFS_SE26.rod
Subsystem 1 - Part No SW: 3D0 941 329 A HW: 3D0 941 329 A Labels: 3D0-941-329.CLB
Component: LeiMo links H05 0012
Coding: 900000
Subsystem 2 - Part No SW: 3D0 941 329 A HW: 3D0 941 329 A Labels: 3D0-941-329.CLB
Component: LeiMo rechts H05 0012
Coding: 900000
1 Fault Found:
13705479 - Databus
U1121 00 [009] - Missing Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 253
Mileage: 193703 km
Date: 2018.03.15
Time: 17:20:32
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5G0 035 874 HW: 5G0 035 874
Component: MU-S-ND-ER 040 0421
Serial number: V7F00610132267
Coding: 02730201FF00000021111201002800001F0100140100010045
ASAM Dataset: EV_MUStd4CPASE 002039
ROD: EV_MUStd4CPASE_SK37.rod
VCID: 67C5AC47CF6D2DBABE6AA51-8032
Media Player Position 1:
Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H51 0022
Serial number: VWZ8Z9NJ901M7G
Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
Part No SW: 5Q0 980 653 E HW: 5Q0 980 653
Component: MQB_MFK H05 0051
Serial number: 00000125971
Coding: 0101010001020304000400000100000101
ASAM Dataset: EV_MFKBoschAU370 001001
ROD: EV_MFKBoschAU370_AU37.rod
VCID: 3A632533EC5F6052112454D-806E
Hey guys - over in the Passat section - someone posted this: http://www.vwwatercooled.com.au/foru...ml#post1236287
Basically in that post, they talk about how they increased the voltage of the DRL's and headlights from 10v to 12v and it's made a "world of difference". Unfortunately they're unwilling to share this information (for free). This was posted a little while ago, so I'm wondering if anybody has managed to figure it out in what section it is?
You know what...never mind - I think this is to do with halogen globes, and not LED's. I thought I could increase the intensity of my LED lights, but I don't think this is the way to go about it. I'll keep digging on this.
As a side note, I've got a kick-to-open bootlid/tailgate. Does anybody know if it's possible to do "kick-to-close" ? I found a VCDS setting for a Skoda Octavia, but in my model 6D-Trunk Elect, I don't have the option to close on kick.
I'm just hoping this is possible through VCDS and doesn't need the VCP tool.
