As I said in my previous response, I've found that the Leuchte-sets are not always allocated in the same way - especially for cars that have different versions of the HID headlight fittings.
But generally, the "dot" Leuchte-sets are Leuchte8FL LB39 (left-side) and Leuchte9FL RB2 (right-side). Before I make a suggestion for your tweak, I'd ask that you confirm my guess about the Leuchte-sets.
If I'm correct, your settings for the left-side dot should be as shown below. Please alter the Dimmwert AB value on your car to a small number. If I'm correct, you should see the dot illumination reduce on the left-side with the headlights switched-on. Revert the setting back to original and please advise your observation
Adaptation channel
Setting
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 |
Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht) |
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 |
Parklicht links (beidseitiges Parklicht aktiviert li & re) |
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 |
127 |
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 |
Always |
