Thanks Sharkie and Lucas![]()
I might be wrong, but I believe the digital dash update is on the MY19+ models (so cars built from around mid-2018 onwards). The one you linked to is a MY18 model, and the 2x I linked to above are both MY19 models. Even the R-Line and GTI got the digital dash so I don't think its got anything to do with some R's being special edition models.
The Wolfsburg might be an exception as you mentioned earlier, as this was a bit of a poverty pack edition from memory.
MY18 Golf 7.5R - Ecotune Stage 1
Mazda RX2 - 13B Bridgeport GTX4202R
I have a Golf 7.5 R (not Wolfsburg) - New from dealer in Oct 2017. It has digital dash and this was standard on 7.5 R at the time.
Hope this helps.
Anyone needing a new battery, I can highly recommend going Lithium, you'll pay more than a standard battery. The battery cost $899 the mounting kit $179 you may also need a charger specific to Lithium batteries also. The big plus apart from lifespan 5-10 years is weight, it weighed in at 4.7kg complete versus the AGM at 20.4kg. It's amazing what taking 16kg off the front of the R does it's worth the money just in the way the front end is more responsive. And if an MK8.5 comes out I can just move it across.
2017 MY18 Golf R Wolfsburg | Oryx White | DSG / 2021 MY21 T-Cross Style | S+V Package | Limestone Grey
Are APR still the go-to for stage 1 tunes for the 7.5 R? Anyone with long term experience?
Seems good value at $999 - yes I could/should go custom but I told myself I wouldn't get carried away![]()
APR honestly still have a killer Stage 1 ECU/TCU package, very few out there can rival it.
If you're considering other options, take a look at Ecotune. A great Stage 1 ECU/TCU package with upgrade paths into Stage 2, 3 and 4 down the line with full Flex Fuelling support.
"Don't get carried away", says the guy with a 4202R powered 13B hahahahaha.
Ecotune Stage 3 MK7 GTI 6MT - Ecotune Reflex - 373FWKW/620NM
Ecotune Stage 3 MK7.5R DSG - Powermax Stage 1 - TBA
Let there be sauce.
A1 are a killer team, Adam (the owner) is both a great bloke, but incredibly technically proficient.
Let us know how you go with either option.
Let there be sauce.
