Results 1 to 5 of 5
Thread: looking for help ACT - mk7.5 grille sensor issue
    Sep 2019
    canberra
    Hi everyone, is there anyone who can assist with resetting of the grill badge sensor using VCDS or other?
    Id like to avoid going to VW is possible.
    Issue: i turned ignition on when the sensor was unplugged when installing LED globes, i had the grille off the car. Noob issue i know, but now we have the yellow dash warning. i tried myself resetting CAN module 13, clearing codes etc, but i simply dont have the specific knowledge to know what im doing..
    if of course it cant be done (needs recalibration?) ill book it in with vw..
    Canberra based.
    cheers
    Mornington Peninsula, VIC
    grille sensor? You mention Module 13 that's the adaptive cruise control module.
    If you have VCDS, click on the AutoScan option, scan the whole car and paste the log on here between some "CODE" tags to make it look good.
    Ross-Tech: VCDS Tour - AutoScan
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    You can run basic settings with the car facing a wall from 1.2m:
    Resolved - VW Golf MK7 2017 Radar calibration. | Ross-Tech Forums
    Sep 2019
    canberra
    Quote Originally Posted by MIG View Post
    sorry been a bit crazy at home. the recorded error from the last scan i had access to is
    Address 13: Auto Dist. Reg Labels: 5Q0-907-572-V2.clb
    Control Module Part Number: 5Q0 907 572 J HW: 3QF 907 572
    Component and/or Version: ACC BOSCH MQB H10 0654
    Software Coding: 3300600111FFC428949C810500300600000000000000000000
    Work Shop Code: WSC 01357 011 00200
    ASAM Dataset: EV_ACCBOSCHVW416 002006 (VW37)
    ROD: EV_ACCBOSCHVW416_002_VW37.rod
    VCID: 3E738BFFA177BC7FFD-806A
    1 Fault Found:
    0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
    C1103 00 [009] - -
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 72626 km
    Date: 2023.09.04
    Time: 13:49:03
    Control Module temperature: 25 °C
    Voltage terminal 15: 12.4 V
    Velocity_vehicle_reference: 0.00 m/s
    Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
    Status_ACC_System: ACC_reversible_error
    Sep 2019
    canberra
    Thanks Kamold, i thought i might have been able to, but i dont have the knowledge of VCDS to understand what i was doing.. borrowed a laptop with it on, and the cable, but couldn't nut it out.. so ill find someone who does and happy to pay beer tokens or whatever is accepted
