Results 1 to 8 of 8
Thread: Cost to replace strut mounts
    May 2021
    Hey guys. I got quoted 1350$ by vw north shore to have my strut mounts and bearings replaced because the suspension is clunking at low speeds and around turns. Considering I’ve seen this type of work being done before the cost sounded crazy to me. It’s a 15 minute job on each side. And it’s a relatively small part. What are you thoughts on this quote? And what do you think is a fair price to have the top mounts and bearing replaced?
    May 2021
    Oh also i got quoted 770$ for front rotors and pads. Thoughts? And do the rotors actually need to be replaced? Their thickness i think was around 24mm
    Strut mount and bearings - that quote is insane. The parts can be purchased from AutoInstruct for about $250 and you can change them yourself if you have some basic tools. Otherwise 1-2hr labour cost from a mechanic.
    I did them myself recently on my Mk7 GTI.
    With you being in Sydney there are so many independent VW specialist mechanics you could use.
    As for your brakes quote, that seems reasonable for genuine disks and pads and labour. But you could buy aftermarket disks for about $150 and then high quality pads for $100-150 and get the mechanic to change them at the same time you do the strut mounts and bearings.
    May 2017
    Southern Highlands
    My front mounts are noisy. Car has only done about 12k since new. Dealer not interested in replacing them under warranty.
    ive got the creaks on my 2017 R which is very common i believe.
    Gemini (Killed), Daihatsu Charade Sold, Peugeot 306 Convertible Sold , Peugeot 306 GTI 6 Sold
    Ford FIesta Sold, Evo 7 Sold , Evo 8MR Sold , Megane 250 RS Sold
    MK7R Lapiz Blue Sold
    MK7R White Current
    Jun 2013
    Got mine done recently $780 BWA Auto Seven Hills. Nice and quiet now.
    May 2017
    Southern Highlands
    Quote Originally Posted by syncro View Post
    Dealer has finally agreed to fix them.
    May 2017
    Southern Highlands
    After 3 years dealer has replaced them. They were faulty from factory. Don't they test drive these things?
