Results 1 to 7 of 7
Thread: CANBUS Spew
    Jul 2007
    CANBUS Spew
    Afternoon,
    Pulled up at traffic lights. Auto-brake engaged, Start/Stop activated, car immediately restarted, and every error in the book came up one by one.
    Scan shows:
    Control unit: 01 Engine
    U112300 - Databus error value received
    U041500 - Invalid Data Received From Anti-Lock Brake System Control Module (x2)
    Control unit: 03 Brakes
    C101D07 - Right rear ABS wheel speed sensor mechanical malfunction
    C101D29 - Right rear ABS wheel speed sensor Implausible signal
    C10E129 - Parking brake motors Implausible signal
    C114602 - Tire pressure monitoring display Signal error
    C10E2F0 - Control module for electro-mechanical parking brake Wheel speed sensor implausible signal
    Control unit: 13 Adaptive Cruise Control
    C10DF00 - Brake temperature
    U112300 - Databus error value received (x6)
    C110BF0 - Adaptive cruise control sensor Restricted view
    C10C200 - Function restriction
    B10E7F0 - Cruise Control Front Distance Range Sensor separated
    Control unit: 22 All Wheel Control
    Control unit: 2B Steering Column Lock
    Control unit: 44 Steering Assistance
    Control unit: 76 Parking Assistance
    (all above have)
    My guess would be that one sensor or wire or control module has gone bad and is putting out garbage data, anyone seen something like this before and have any ideas?
    Also, anyone know good VW/Euro specialists in Sydney who aren't just going to replace modules and sensors until they find the broken one and then bill me for all of it?
    CANBUS Spew
    How old is your battery? If the battery is on its last legs then all sorts of weird electrical gremlins pop up.
    Where in Sydney are you, in order to try and recommend a VW specialist to help diagnose?
    Jul 2007
    About a yr old. Replaced with a good AGM and S/S has been working great since. Usually S/S shows different behaviour as the battery starts to go bad.
    Jul 2007
    A bad wheel speed sensor can cause and ABS or traction control warning light as well as causing some speedometer issues.
    With the help of the ABS speed sensors, the Tire Pressure Monitoring System (TPMS) compares the speed and rolling circumference of the in‐dividuals wheels.
    It seems there's a different ABS speed sensor for vehicles with adaptive cruise control and electronic parking brakes, so a guess would say that a faulty sensor could cause issues in most of the systems mentioned in the scan. I think I'm going to unplug it and clear the faults and see if all the 'error value received' messages go away and are just replaced with faults that the sensor is missing or failed, and then arrange to replace it.
    Hopefully one of the resident VW electrical gurus will chime in with their thoughts for you. Im pretty good mechanically, but with electronics I have no interest so I can only offer so much advice.
    Jul 2007
    For some reason I didn't think of it before, but I ran the live data for ABS Speed Sensors for all four wheels, and three of them are registering the correct speed, but the right rear sensor is not. Ordering a replacement and hopefully don't find that it's a damaged cable or similar when I get the car up on a hoist.
    Quote Originally Posted by LiFers View Post
    Actually the speed sensors failing are a somewhat common issue on the Mk7’s, so chances are thats your problem given one of them is not giving a reading.
