Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Assistance Needed for Programming BCM for LED Fog Lights on VW Golf MK7 (2014 TDI to
    Alek: Bummer!!!
    Alas, I don't understand any of your words in your response above that starts "Ok, so I am isolating errors specific to LED errors. These two replace this from long coding to channel coding..........."
    I reaching the end of my suggestions - I ask once more:
    Maybe post-up a BCM admap (as a URL link - don't dump the data directly in your post) so we can see how this puppy is programmed!!
    If you aren't familiar with the process of creating a BCM admap with VCDS, see my instructions below:
    From the VCDS opening screen below, select Applications
    From Applications screen, select Controller Channel Map
    In the Maps dialogue box, set-up the variables EXACTLY as shown below (take care with this step - check the boxes correctly):
    Press the Go button and wait for the magic to finish!
    Once the process is complete, look in the sub directory C:\Ross-Tech\VCDS\Logs on your laptop and you should find a new file starting with the name admap-09-5Q0-937-084-AC.......CSV.
    Now, because this forum won't accept a .CSV file, you will need to post-up the admap to a third-party hosting site (like dropbox, or any of the lots of other sites). Then include a URL-link to the file in a new post here
    Jul 2011
    Perth
    Hi Don,
    Here is the link where to download the file. Also included the text file format along the VCDs export CSV
    Al
    Unique Download Link | WeTransfer
    1. Update Fog Light Adaptation Channels
    Left Fog Light (Leuchte12NL LB45)
    Current Settings:
    Lasttyp 12: 6 - LED Lichtmodul ✅
    Dimmwert AB 12: 127 ✅
    Fehlerort mittleres Byte DTC-DFCC 12: 00 (Error reporting disabled).
    Missing: Kaltüberwachung aktiv (Cold Monitoring Active).
    Right Fog Light (Leuchte13NL RB5)
    Current Settings:
    Lasttyp 13: 6 - LED Lichtmodul ✅
    Dimmwert AB 13: 127 ✅
    Fehlerort mittleres Byte DTC-DFCC 13: 00 (Error reporting disabled).
    Thanks mate
    Al
    Al: hmm.......... that's a mighty odd BCM admap!
    Your BCM has P/N & S/N 5QO-937-084-AC. The nearest BCM in my database is an Aussie 5Q0-937-084-AE. I've created a BCM compare spreadsheet for the 2 x modules that you will find HERE
    This is how the spreadsheet works:
    Worksheet "BCM compare AC and AE"
    1. Contains a list of ALL channels and values in your BCM compared to the AE BCM - if the AE BCM has the same channel name
    2. The last column "Same?" asks the question if the settings are identical in the 2 x BCMs for each channel
    3. I've sorted the results by the "Same?" column with "No" first (because these will be of greatest interest to you)
    4. There are 2 x types of "No" results: If the 2 x modules genuinely have different values and if the AE BCM does NOT have the channel
    Worksheet "AE channels not in AC"
    1. Contains a list of channels that appear in the AE BCM - but the same channel is NOT in your AC BCM
    As you will see - there are multiple (meaning many) "No Response From Subnet Component" values in your BCM! AFAIK, these BCMs don't have a Subnet!! MQB platform BCMs certainly don't use a Subnet mask because they don't have an IP based network - so the many, many instances of "no response......" in your admap is very strange!
    What is the back-story for the BCM in this car? Shirley it can't be the factory installed module - or if it is, has there been some serious software tinkering?
    PS: The fog-light Leuchte-sets look OK
    Jul 2011
    Perth
    Thank you Don, I appreciate the help thus far.
    No history with the car that I know off. The wife drove for the last 3 years and had little front damage so I opted to upgrade the entire bumper and fog-lights from Gti . This is the TDI 110kw model R edition. So no issues previously.
    Jul 2011
    Perth
    I'm guessing you are implying this will have to be a firmware update, replacement, or resistors ?
    Quote Originally Posted by ak77 View Post
    No to "firmware update"! As I've said a number of times in this thread, the fact that a 12V signal appears at the fog-light connectors (with the fog-light lamps connected) when the fog-light switch is activated means that the BCM is properly operating the fog-light function. My understanding from your responses is that this happens. So more coding and/or firmware updates won't (shouldn't) change this BCM outcome.
    In requesting the BCM admap, I was hopeful that I could spot another reason for this problem. But despite the mighty strange admap that you have provided - none of the weirdness dispels the fact that the BCM is operating the fog-light function correctly at the connectors.
    So I'm not sure how familiar you are with electrical theory - but this situation seems to be one where the BCM is supplying the correct voltage, but no electrical current is flowing out of the BCM. If I was looking at this problem anew, I would suspect that the fault was due to incorrectly polarized LEDs. As I assume you already know, LED is short for Light-Emitting-Diode and diodes conduct ONLY if the +ve voltage is connected to the anode lead. If the +ve voltage is instead connected to the diode's cathode lead, the LED won't conduct resulting in "no electrical current flowing"
    But, I assume that when you hook-up the temporary battery supply to confirm that the fog-light lamps actually work. you connect the +ve/-ve battery leads to the connector pins with the same pin polarity as the the way that the BCM supplies power.
    So, because we have ruled-out coding and reverse-polarity as possible causes for this problem and because you have assured me that the LEDs work properly - I'm scratching my head!!
    Jul 2011
    Perth
    Yes mate above all tried and tested. I really wanted to have the LED lights at fault here but they function isolated outside the BCM. The only other thing I haven't tried is tricking the BCM the I'm still running the halogens by adding resistors.
    But honestly mate , you ben excellent and learnt heaps Cheers.
    I'm at the give up stage , or so close to it
