Click HERE to order or for more information.
VW MKV Jetta 2.0T Ignition Service Kit - Only $124.95!
Is your ignition system coiled and ready to strike?
Make sure your plugs are firing at voltage levels that ensure optimal combustion and peak performance. If your old coils are tired and unable to do the job, an ignition service kit from ECS Tuning will put some zap in the gap when you need it most.
Our ignition service kits are easy to install and come with everything you need to restore secondary ignition efficiency firing at voltage levels sure to get the most from each and every power stroke.
OEM. OES. GTG.
