Results 1 to 10 of 58
Thread: Superb 206TSI Review
    Apr 2012
    BIRRONG
    Yes woofy, a full size spare fits.
    The toy spare has after all to be the same diameter & the depth is there.
    There is not a hint of rattle or squeak anywhere, by the way. I mention that as one motoring writer seemed to focus on that in one Australian review. He reckoned it was the umbrella in the door. Presumably they were the same as mine & they're a very tight fit.
    The windscreen sticker declaration of fuel & emission levels is surprising. It shows the CO2 output from the engine as 169g/k. The Czech configurator site displays 199g/t for the same engine. One of them must be right!
    Apr 2012
    BIRRONG
    2150kms on the clock including some longer distance driving on the express ways & country roads.
    The car remains fantastic. I have changed my Individual Mode setting to Sports Handling & Sports steering with the other settings remain 'normal'. I find this gives me much better 'road feel' & sharpness to handling.
    Some of the car's Driver Assist software is frustrating. Each will need to fiddle with setting to find what suits them. My pet hate is the way Adaptive Cruise Control automatically engages, whether you like it or not, as you come up behind a car on an express way. The factory setting see it engage & start slowing the car, m 50-400 metres before you get near. I have had to set vehicle distance to the absolute minimum, titled 'very close', for such driving. It really is infuriating, because once engaged, it resets the set speed to the lower figure. ACC might be good on autobahns, but not on our roads where drivers spread across the road like Brown's cows, regardless of speed & intent to overtake. When fiddling with Driver Assist settings, learn Skoda's terminology to avoid turning off what is desirable.
    The one 'feature' I'd like to get rid of is, Lane Assist functions which keep trying to steer the car into the middle of the marked lane, for you. There is absolutely nothing more frightening than feeling the steering wheel being tugged in your hands, as you are trying to take a precise line into a fast corner, on a typical uneven, potted NSW country road! It is a feature for inattentive drivers & another of those features which have invaded modern cars, like ABS. It is not aimed at improving the car, but substituting for those lacking basic driving skills..
    With some balance between city & touring I can confirm fuel consumption is on the manufacturers claimed figures of 'City-9.1/open road-6.3 & combined-7.3. That is, as long as you don't spend extended periods giving it heaps in full Sports mode; 11.8 might be more likely, if you do.
    I must again compare this 206Tsi with the previous 191Fsi V6. This engine is far livelier & responsive when you demand it, than the R36 V6 motor. You put the foot down in this 206 & I guarantee you will be 20kms faster than you wished, before you realise. Where the motor & DSG do get caught short is on a steepening road, when on cruise control at 100kph, in D6, with the engine around 2k-2.5k revs. The 2.0l doesn't have the torque to respond in that situation. It tries to hang onto the higher gear too long & will lose 10-20k/hr of momentum before changing. The answer to avoid this is for 'road aware' drivers, to give the DSG a flick into Sports mode on approach to such sneaky rises. Wake it from its slumber.
    Every time I start the car, the first thing I do is, disable 'Engine Stop-Start'. It is too tardy restarting & waking up the DSG. It strikes me, this is a big contributor to slow traffic movement at light changes. I have to think about this, but I suspect Start-Stop is not really a genuine 'green' feature. Sure it will cut tested emissions from an idling engine, while no kilometres are being clocked. But in an electronics intensive vehicle, demanding many engine restarts in traffic, there must surely be a broader environmental cost to tardy traffic flows, increased load on generators for battery charging. Sure it will reduce the figures for one vehicle tested in isolation; but I question its environmental value in the broader scheme of things.
    I previously made comment on the Pirreli P7 tyres being surprisingly quiet on the road. That is true on smooth surfaces, but on coarser gravelled asphalt roads over the weekend, they were as disturbingly noisy at the back end; as bad as Dunlop Sports Maxxx proved to be on my 3T V6 4x4. Mind numbingly resonant! At this stage, I'll keep them, after all they're new & 235/40/19tyres ain't cheap. If the diabolical & rhythmic howl in the back continues when we're cruising in the country, the Pirellis will likely bite the dust & be replaced by ContiSport3s or Michelin PS3s. Noise abatement is one area Europe cars tend to fall well short on our variable surfaces.
    This follow up is intended to give some pointers in finding personal preferences in setting up & driving a 206. Make no mistake, this is a fantastic car. The tyres are the one thing I think fall short, undoubtedly magnified by the 4x4s active rear end.
    Dec 2010
    Helensburgh
    Your dislike of all the driver assist, active cruise control etc is exactly why I want one. I drive 95% of the time on multi lane roads for long distances and I have found the ACC on the Golf very good. On my Superb I am constantly on and off the cruise control trying to allow for cars that vary in speed etc and the ACC on the Golf takes all that away. I can also drive the Golf in stop start traffic with no input from me except to press the resume button or manually start it off if necessary and it makes stop start traffic a doddle to drive in. The engine stop start is what it is and after a while is not even noticed or at least I don't notice it. I don't think I would worry too much about the suspension stuff as I have never regarded the Superb as that type of car, if I want to go for a quick drive I choose the PP because it is that type of car but then not everyone has a choice.
    Apr 2012
    BIRRONG
    So, are you saying the system in the Golf is different & superior?
    Dec 2010
    Helensburgh
    Quote Originally Posted by 2009fsi View Post
    In my view yes. The system on the Golf is the same as the new Superb less traffic jam assist whatever that is, my Superb is old school manual as you would have had in your previous car. For my purposes the ACC in the Golf is a thousand percent better everywhere and in the end much safer because it automatically holds the set distance for the speed being driven at. Yes, it takes some getting used to and the driver in fact has to be on the ball because if a slow car is encountered the speed drops off and is not noticed and for this reason the driver cannot just set and forget. How I use it is to set the speed higher than the limit on the road and start off following a car and if that car is too slow I pull out and the car accelerates and passes, pull back in and when I encounter a car doing the speed I want I stay there otherwise it is just moving through the traffic without touching the accelerator or brake and just steering the car as needed.
    In traffic basically the same and when the car stops automatically controlled by the car in front the resume button gets it going again or a push on the accelerator if the stop time has been extended. I am fascinated by what Skoda call "traffic jam assist" and what it does over and above what the Golf does, maybe it is the same thing but VW do not give it a name in the Golf. I liked the Superb lane assist on the shortish drive I had as the car will track on a multi lane road with no input from the steering wheel but it is disabled below a certain speed.
    Horses for courses I guess and that is why there are different cars to suit different drivers needs. As far as new technology goes we ain't seen nothing yet and I can't wait to see what they come up with next. I hope the next Golf has the new TFT dash, that will be fantastic. I think VW have held it back on the Passat for a mid model facelift which is understandable but disappointing and the same might happen with the Superb if we are lucky.
    Mar 2015
    Warner, QLD
    Quote Originally Posted by Ozsko View Post
    If it's anything like the Audi's Traffic Jam Assist, which I'm betting it's the same thing, it takes over braking, accelerating and steering up to a certain speed. So basically, it's hands off. You don't even need to hit resume for the car to move off from dead stop. It just follows the car ahead and keeps it in the lane.
    Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
    Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
    Dec 2010
    Helensburgh
    Quote Originally Posted by agentthumb View Post
    That sounds like my kind of gadget, I know lane assist and ACC work only from a certain speed.
    Apr 2012
    BIRRONG
    It is exactly the same agentthumb & Ozsko.
    In theory, you should be able to sit back read a book. Or retire to the backseat to do whatever you like, in peak hour traffic, as long as you put the blinds up. It works up to 60ks/h. ACC Plus!
