Further to this. Will drop into VCDS thread also.
Friday,20,October,2017,09:50:07:40733
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1 (x64) HEX-NET CB: 0.4401.4
Data version: 20170721 DS276.2
Ross-Tech: Home
Mileage: Repair Order: 201017
Address 6D: Trunk Elect.
Control Module Part Number: 7N0 959 107 A
Component and/or Version: HDSG-Modul H11 0802
Software Coding: 082301C002
Work Shop Code: WSC 33361
VCID: B522611A14DEEBEEE9-80E0
Advanced Identification/FAZIT
Serial number: 250000031
Identification: TF7-MNL
Revision: 41011001
Date: 07.09.10
Manufacturer number: 0001
Test stand number: 0031
Flash Status
Programming Attempts(application): 0/0/0
Programming Attempts(data): 0
Successful Attempts(data): 0
Programming Status: 00000000
Flash Date: 00.00.00
Flash Tool Code: 00000 000 00000
Flash Tool Code(data): 00000 000 00000
Software
UDS: 01.02.14
Diag: 01.03.00
CAN: 01.26.01
ISO15765: 01.02.15
UDS Std Diag: 01.01.00
Theft prot.: 00.00.00
OSEK-OS: 03.24.00
OSEK-Com: 04.07.02
Unknown: 01.00.08
Misc.
Hardware number: 7N0 959 107 A
Workshop System Name: ----
Equipment/PR Code: 0000000000000000
Dataset Number: 7N0959107A
Dataset Version: D009
ASAM Dataset: EV_HDSGSk462
ASAM Dataset Revision: 301133
Car Info
Chassis Number: -----------------
VCDS Info:
Labels: 7N0-959-107.clb
ROD: EV_HDSGSk462_SK46.rod
Friday,20,October,2017,09:51:25:40733
Ross-Tech: Home
Address 6D: Trunk Elect. Labels: 7N0-959-107.clb
Control Module Part Number: 7N0 959 107 A HW: 7N0 959 107 A
Work Shop Code: WSC 33361 790 00999
ASAM Dataset: EV_HDSGSk462 301133 (SK46)
1 Fault Found:
0004 - No Basic Setting
B2010 00 [137] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 129
Mileage: 126440 km
Date: 2080.14.29
Time: 10:46:56
12.64 V
