Hi guys, if you could point me in the wright direction.
My rear wiper and washer pump (front & back) don't work.
My front wipers work just fine.
I have tested all my fuses and they all work. I pulled the washer pump out and tested on 12V independent and found the pump to be operational just fine (loud and noise as they normally operate) .
Should I be looking at some sort of relay somewhere? My VCDS diagnostic doesn't show anything wit this subject matter at all.
I have further isolated the two fuse seats at 41 and 42 that control windshield washer pump and cigaret lighter are inactive,... although the 20A fuses are in correct position and working (tested in another slot and multimeter) .
Is there a reason why entire line in a row in Fuse box would be inactive?
_____
Update,
I have bypassed the two fuses with direct wire connection of the battery positive to the two seats.
Everything worked perfect. Obviously all the components work ( pump, motors etc), but the power is not getting to the second last row (fuse box) 41, 41, 42 ,43, 44, 45//
Does anyone have a clue here how I should proceed. Does this sound like the wiring issue or possibly J519 Control Module.
I hope someone reads this post
