Results 1 to 10 of 16
Thread: Getting phone button to work
AUC-05L Getting phone button to work 12-08-2016, 11:06 PM
Guest001 Isnt it just a mute button 13-08-2016, 07:10 PM
AUC-05L No pbone button there to... 13-08-2016, 08:31 PM
Guest001 Oh well doesnt on mine 13-08-2016, 09:08 PM
kamold The phone button will act as... 14-08-2016, 08:16 AM
AUC-05L Thanks for that. Checked that... 14-08-2016, 05:51 PM
kamold What is the part number of... 17-08-2016, 06:31 PM
AUC-05L Hi. Photo attached... 20-08-2016, 05:50 PM
kamold Check the long coding helper... 22-08-2016, 09:31 AM
twwyt From What I have read, the... 20-08-2016, 11:01 AM
JustCruisn Wow what a PITA. I have a... 20-08-2016, 01:01 PM
mr gee I activated mine on a 2013... 20-08-2016, 04:25 PM
AUC-05L I got the harness too. Like i... 20-08-2016, 05:51 PM
JustCruisn I have the same part number... 22-08-2016, 11:02 AM
AUC-05L Does your jetta have the dsg... 23-08-2016, 07:03 PM
JustCruisn No paddles Sent from my... 23-08-2016, 07:04 PM
    Aug 2008
    SYDNEY
    Hi all.
    I recently installed a rcd510 and 9w7 bluetooth module. Everything works great except for the phone button on the steering wheel.
    I know i have to go to module 16 steering wheel controls on vcds but what code do i need to activate the button?
    Any help would be greatly appreciated.
    Sent from my SM-G900F using Tapatalk
    2008 POLO GTI - SOLD
    2005 MkV Golf GTI - couldn't resist
    Pacific Paradise QLD
    Aug 2008
    SYDNEY
    No pbone button there to answer and end calls.
    The phone button will act as a mute button if there is no bluetooth module installed.
    Firstly check that you have enabled address 77 Telephone in the Canbus gateway installation list.
    Then check the following info for coding info on the steering wheel and BT module:
    The Official VWW VCDS Tweak Library
    Aug 2008
    SYDNEY
    Thanks for that. Checked that coding and i dont have the push to talk option. Anywhere.
    What is the part number of your steering wheel controller? Address 19 from memory
    Aug 2008
    SYDNEY
    Hi. Photo attached
    Quote Originally Posted by AUC-05L View Post
    Hi. Photo attached
    Check the long coding helper for the module. I don't have the same module so I can't be sure that this is correct from the label file:
    Steering Wheel Electronics (J527) Coding
    0?xxxxx: Vehicle Type
    0 = Normal / 1 = Special Purpose (e.g Taxi)
    0x?xxxx: Transmission
    0 = Manual Transmission
    1 = Automatic Transmission
    0xx?xxx: Steering Wheel
    0 = Steering Wheel without Multifunction
    1 = 3-Spoke Steering Wheel without Multifunction
    2 = 3/4-Spoke Steering Wheel with Multifunction without Cruise & Voice Control
    3 = 3/4-Spoke Steering Wheel with Multifunction with Cruise & Voice Control
    0xxx?xx: Additional Equipment
    +1 = Tiptronic (Shift Paddels)
    0xxxx?x: Board Computer / Cruise Control System (CCS)
    0 = w/o Board Computer and w/o Cruise Control System (CCS)
    1 = with Board Computer and w/o Cruise Control System (CCS)
    2 = w/o Board Computer and with Cruise Control System (CCS)
    4 = with Board Computer and with Cruise Control System (CCS)
    0xxxxx?: Rear Wiper
    1 = Rear Wiper not installed
    2 = Rear Wiper installed
    If this is the correct label file then you have 0xx?xxx set to 2=3/4 spoke steering wheel with multifunction without cruise and voice control. Try changing this to 3 and test it ie your new coding will be 0013122.
    Aug 2016
    Adelaide, South Australia
    From What I have read, the 9W7 will not work with the mk5 (I also have it in mine).
    It only means you can only use the head unit to interact with the phone. I believe the only way to make it work is if you swap to a MK6 steering wheel.
    Also swapping to a cluster with white MFD will give you MFD menus for phonebook etc.
    I decided that's a bit too much work for now and just use my RNS-510 screen to use the phone.
