Results 1 to 10 of 16
Thread: Getting phone button to work
    Aug 2008
    SYDNEY
    Hi all.
    I recently installed a rcd510 and 9w7 bluetooth module. Everything works great except for the phone button on the steering wheel.
    I know i have to go to module 16 steering wheel controls on vcds but what code do i need to activate the button?
    Any help would be greatly appreciated.
    Sent from my SM-G900F using Tapatalk
    2008 POLO GTI - SOLD
    2005 MkV Golf GTI - couldn't resist
    Pacific Paradise QLD
    Isnt it just a mute button
    Aug 2008
    SYDNEY
    No pbone button there to answer and end calls.
    Oh well doesnt on mine
    The phone button will act as a mute button if there is no bluetooth module installed.
    Firstly check that you have enabled address 77 Telephone in the Canbus gateway installation list.
    Then check the following info for coding info on the steering wheel and BT module:
    The Official VWW VCDS Tweak Library
    Aug 2008
    SYDNEY
    Thanks for that. Checked that coding and i dont have the push to talk option. Anywhere.
    What is the part number of your steering wheel controller? Address 19 from memory
    Aug 2016
    Adelaide, South Australia
    From What I have read, the 9W7 will not work with the mk5 (I also have it in mine).
    It only means you can only use the head unit to interact with the phone. I believe the only way to make it work is if you swap to a MK6 steering wheel.
    Also swapping to a cluster with white MFD will give you MFD menus for phonebook etc.
    I decided that's a bit too much work for now and just use my RNS-510 screen to use the phone.
    Jul 2007
    Brissy
    Wow what a PITA.
    I have a cheap Sony unit, I added the CAN-BUS adaptor for it and the phone button works, the star button does ATT mute.
    No buttons to change tracks however.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Mar 2009
    Melb
    I activated mine on a 2013 Beetle with this harness from Ebay. It replaced the harness between the bluetooth module and RNS510(in my case) You also need VCDS to activate it. It may or may not work in your case but something to look into.
    WIRING HARNESS VW BLUETOOTH FOR Rcd510 MFD3 WITH VOICE CONTROL | eBay
    Tig 162 R-Line; Audi TT
