Results 1 to 10 of 16
Thread: MkV GTI Cold Melbourne Mornings - Warming Engine Up
    Oct 2009
    Bentleigh East, Melbourne
    how long does it take your car to warm up now with colder mornings?
    is 25-30 mins too long?
    Me thinking thermostat is stuck open.... especially as temp seems to be coming back from 90 on the freeway, to around 75-85.
    Are you looking at the temp gauge or the HVAC diag channel 19.2
    The temp gauge is more of an idiot light, mine points to 90 from actual 75 - 95+ degrees.
    But yeah, i'd expect heat from a petrol engine in under 5 minutes with normal driving. Idling, much longer.
    Dec 2009
    Kew, VIC
    Strangely, a stuck open/corroded away/missing thermostat can also cause overheating — the coolant circulates so fast it doesn't have time to cool properly.
    Nov 2008
    Once the engine warms up, my temp gauge on dash always indicates 90 degrees regardless of outside ambient temperature (40 degree ambient differential between summer/winter). Either the cooling system does a fantastic job of regulating temperature to 90 degrees, the ECU does some adjustment to give the driver piece of mind or my temp gauge is busted and doesn't go past 90 degrees. Is this normal?
    MY09 MKV GOLF GTI | RS | 5D | MT
    Dec 2009
    Kew, VIC
    Quote Originally Posted by doink View Post
    Seems to be — Mk6's do the same thing.
    Probably a way to use a cheaper gauge. Presumably it'll go up if the coolant boils.
    Jan 2008
    Quote Originally Posted by Idle View Post
    It's there because there are so many stupid owners that would worry if the gauge moved and you'd have posts all over the forums with people comparing their temperature with someone else's and so on. If people weren't so stupid and understood a little more about cars in general it wouldn't be a problem.
    May 2009
    Frankston, Vic
    Quote Originally Posted by Maverick View Post
    Well put!!
    Apr 2010
    Bunbury, WA
    On a really really cold night if i sit in my car with the heaters on and at idle for an hour or so the temp gauge will go down. They (1.9TDI) dont make much heat, and after a hard acceleration the heat coming through the vents even with a hot motor is noticebly hotter.
    Dec 2009
    Paddington NSW
    My GTI will hit 90 with in 2-3 minutes of driving.
    I always thought this was to quick. starting to think i am right.
    Dec 2008
    no boost, 5-10 min, 50km/h with a little stop start.
    boost = 3 min. tops. try to let the oil move around first before hitting 4k or above.
