Results 1 to 10 of 10
Thread: Jetta tdi no go
    Jul 2010
    Gympie Queensland
    Unhappy Jetta tdi no go
    Good morning fellow enthusiasts.
    Tried to start my 2010 1.6 Jetta TDI this morning. It cranked over showing no signs of firing.
    I tried again after letting the "glow plug heat up till long after the light went out; same.
    Tried again after listening for fuel pump running then stopping. Something ran then stopped.
    If the glow pug was cactus; I imagine the engine would start with a few coughs ???
    Any ides? Anyone? Please!
    May 2013
    Darwin
    Jetta tdi no go
    Have you got a multimeter so you can test the voltage of the battery ? Does it make the cranking sound ? But not turn on?
    May 2013
    Darwin
    Jetta tdi no go
    Sorry u did say it cranked over lol. Have you got it scanned ? It could be anything.
    How long have you been letting it crank for?
    Jul 2010
    Gympie Queensland
    I have a multimeter. Original Jetta battery coming up 5 years. I have a Hilux and jumper leads. Jetta turned over quite vigorously this morning-but a bit on the flat side now.
    Jul 2010
    Gympie Queensland
    Haven't had it scanned. I'm out in the bush and the nearest VW workshop is over100 ks
    Jul 2010
    Gympie Queensland
    Anyone experienced a failed glow plug?
    Dec 2014
    if 1 glowplug has failed then it would start up with a bit of a missfire. whats the volt reading when its craking?
    Pacific Paradise QLD
    Flat battery I bet
    Jul 2010
    Gympie Queensland
    Should have put money on it Hillbilly-jump started off a Hilux using jumper leads. Think its time to get a new battery.
    Thanks for the help, guys.
    May 2013
    Darwin
    I thought so. From my first comment I said to use a multimeter
