Results 1 to 10 of 10
Thread: DSG Gearbox Click/Clunk 3rd-2nd
dbun DSG Gearbox Click/Clunk... 30-10-2010, 03:38 PM
satz Is it happening when cold, or... 30-10-2010, 03:59 PM
dbun both times when I started... 30-10-2010, 04:05 PM
DNA Tuning Looseness/clunkiness in what... 30-10-2010, 08:55 PM
dbun oh okay....that could be... 30-10-2010, 09:38 PM
DNA Tuning It is more or less under the... 30-10-2010, 10:12 PM
dbun It's more of a 'click' than a... 31-10-2010, 12:45 PM
dbun got no idea what it was. I... 31-10-2010, 09:39 PM
DNA Tuning That's good to hear; I guess... 31-10-2010, 09:45 PM
dbun too true.....quite possible... 31-10-2010, 10:03 PM
    Oct 2010
    Croydon North, Melbourne
    oh okay....that could be possible. The gearbox oil was changed at the 60,000km service (now at 71,000km) and it's been fine since then, but I guess it doesn't hurt to maybe flush it again.
    The sound does seem to come from the front/engine bay, but because I feel it through the brake pedal and it occurs at the same time it downshifts from 3rd to 2nd or 2nd to first, it's what had me thinking it was the transmission. It's possible that it's just a coincidence that it occurs at that time.
    Where does the gearbox sit physically in terms of the car floor?? Is it directly under the gear-stick/center console? more towards the front or back? etc
    Also, because I hear of the horror stories with the DSG gearbox failing, I automatically assume the worst :p
    Sep 2010
    Melbourne, Victoria
    It is more or less under the gear-stick; I find it odd that you can feel it through your brake pedal however. Also, is it more of a "clunk" or a "click"; and does it cause any sudden jerks in the motion of the vehicle? If it's a loud/boomy "clunk" noise along with a sudden jolt/backlash of the drivetrain/vehicle then it does sound a transmission related symptom.
    It might also be worth pulling your battery to reset the onboard computers which control the engine/transmission as it "develops" its behaviour over time based on what it thinks is ideal for your car and your driving rituals/habits/routines. Make sure you've got your radio code handy so you don't lock that out.
    Also, try doing the shift manually to see if you can replicate it more readily (ie. try downshifting from 3rd to 2nd at a variety of speeds/brake load conditions, uphill/downhill etc.) to see if you can establish a pattern.
    Oct 2010
    It's more of a 'click' than a 'clunk'. It's not violent or jerky at all. The car keeps going on as smoothly as before.
    Actually, if it been doing it since I'd taken the car over and it was across all gears, I'd think it was a completely normal 'click' of the transmission changing gears.
    It's the fact that it's never done it before and only does it on the 3rd-2nd or 2nd-1st down-shift that has me questioning it. It's never made the noise on the up-shift or on any other gear changes, only ever on the down shift intermittently.
    It may not be coming directly through the brake pedal, it's just the fact that because I'm braking at the time my foot is on the brake pedal. It may coming through the floor, but because I'm braking at the time, I feel it through the brake pedal, if that makes sense.
    Oct 2010
    I took it out for a drive today somewhere and on the way there and back I tried to replicate the 'clicking' noise I heard and felt the two times before. No matter what I did I could not replicate the noise.
    I drove in normal 'D' mode as I normally did.....nothing
    Chucked it in 'S' mode and let it rip.......nothing
    Chucked it in 'Manual' mode and shifted through the gears and even downshifted as aggressively as the car would let me (as the DSG won't let you over-rev the car) and still nothing.
    I'm pretty convinced my DSG is safe (for now anyway), as no matter what I did, the gearbox was as silky smooth and as quite as normal. I'll keep an ear out for it, but for now, I'm pretty satisfied it's nothing major going wrong.
    Sep 2010
    Melbourne, Victoria
    Quote Originally Posted by dbun View Post
    That's good to hear; I guess one thing to mention is that at the end of the day; it is still a mechanical device composed of dozens of moving parts - electronic control has come a long way, but 100% consistency under all conditions is still difficult to achieve.
    Oct 2010
    Quote Originally Posted by DNA Tuning View Post
    too true.....quite possible it was just a once of thing, who knows.
    Either way...thanks heaps for the replies and support!!
