Results 1 to 10 of 19
Thread: Drivers Window not working
    Apr 2011
    I've done a search and didn't find anything that could help a noob like me.
    Today I had an issue with my 2005 Golf Tdi. I parked at the shops and the drivers window was down about 3 inches and now it won't move. All the other windows work as normal. I've tried resetting by using the key in the door, but still not working.
    I'm assuming the window motor is stuffed. Could it be anything else? It pissed down with rain on the way home which furtehr added to my happy mood.
    Im going to pull the door apart tomorrow, if it is the motor, where is the cheapest place to buy a new one? VW dealer?
    any advice appreciated.
    Dec 2009
    Kew, VIC
    Check before you buy parts — it may only be a bad contact.
    Also these models are known to have a problem with the wires breaking where they flex when the door opens and closes.
    Naturally, it's most common in the driver's door.
    As to replacement cost I haven't a clue, but the cheapest supplier won't be the dealer — Google is your friend here.
    Dec 2008
    Sydney/Canberra
    ^^ This.
    Where the wiring harness passes from the door to the A-pillar, peel back the rubber boot. You'll probably see a few broken wires in there.
    I highly recommend replacing the wiring harness, even though it's a cow of a job. You need to remove the outer door skin to get at it.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jun 2012
    mine does this also, but it does work.
    It goes up and stops about 10cm from top then goes back down, it doesnt do it all the time.
    Its a pain when it rains and you need it to go all the way up and it refuses to sometime.
    Any ideas?
    11 MK6 Golf R- Name: Sully - bits of stuff and code and stuff to make it a bit faster i hope
    Dec 2009
    Kew, VIC
    Quote Originally Posted by steve_666 View Post
    Any ideas?
    Could be a wiring fault, but my first move would be to check for a sticky section in the glass channel — maybe spray a bit of silicon or teflon lube into both channels (not WD40 or any other petroleum based lubricant.)
    If you can find one, I've found teflon-based sprays work better.
    Apr 2011
    I went out to the garage yesterday and said to the missus..."it would be nice if it just worked today" and sure enough, i put the keys in the ignition and pulled up on the window button and the window went up. Weird problem. It is now working fine, yet yesterday it wouldn't budge.
    Mar 2008
    Chatswood, NSW
    This happened to my passengers side window, but the window still worked when I held the lock or unlock button on the remote.. I pulled the drivers side master power window switch out and put it back in and now it works fine..
    MKV GTI
    Jun 2011
    Sydney NSW
    Check for obstructions as well.
    If the drive experiences a high resistance to movement, it might think that it has reached the end of its travel and so shut off.
    Mar 2008
    Chatswood, NSW
    Sorry for the thread jack, but whilst were on the topic of power windows has anyone else notice an annoying bug with the windows where you one touch the master (on the drivers door) switch to bring the windows automatically, they roll all the way up but then once they reach to the up position they automatically go back down about half way.. I have noticed my car goes through phases of doing this, it seems ok at the moment but for a while there it was doing it often, was very annoying.
    MKV GTI
    Pacific Paradise QLD
    Quote Originally Posted by jessv3 View Post
    If you hold it down to long I believe it does that as its supposed to as a way of cooling the car before you get into it Was a thread about it last week on HOW TO DO IT With the remote You havent got the remote in a pocket with other stuff and its self activating have you
