Results 1 to 10 of 18
Thread: Door Lock installed but external handle now a bit loose.
    Apr 2010
    granville, sydney
    thanks for the link guys will pick one up
    i'd actually picked one up before christmas last year, seemed to open from the outside fine but once you close it and it locks the inside handle won't unlock it on the first pull to open it and once that happens the handle on the outside won't open it either
    as for your loose handle problem, did you set the handle preload? described in this video
    just realised the link in the above post doesn't work, got the seller name?
    cw.mkv.gti.034ms,s2+
    Quote Originally Posted by vinnY View Post
    Hi mate, the ebay seller's name is hatchso, give this link a whirl: Front Left Side Door Lock Mechanism 9 PIN Fit VW GOLF MK5 Jetta 2003-2008 2009 | eBay
    Also, I didn't set the handle preload just seated the plastic handle properly into the springed clip upon reinstallation and all's working as expected. I haven't experienced the issue you described with the new locks. that sounds like what was happening with the one i replaced. (would only open on second pull from inside handle only).
