Same boat here Neil.
My hesitation with the faux leather is the longevity of the fabric for the efforts of the job. It's really not upholstery grade fabric is my first concern. It will tare easily if not flake off before too long due to the grade of the fabric and it'll give more and more over time.
I have just had the roof-lining and pillars done and the marine upholsterer said minimum 200$ a door card, FYI. Purely because it's a nasty job. As you have done the cards before, would you recommend any YouTube videos of best way to tackle the replacement, please?
My conclusion is to do the replacement myself as I am in Far North Queensland the faux leather just won't last. I'm looking at leather by the metre from a Saddlery and Spotlight have a small range up here too.
Fortunately, when studying at uni I worked as a PT furniture upholsterer. So, I'm hoping to use the existing cards as a template for cutting the fabric. Although, do you recommend replacing the thin layer of foam or skip it entirely? Based on your experience? I have seen other vehicles come up well both ways. Ideally I would like to avoid the foam all together unless the armrest is too rough without it. Essentially, I'm hoping that the good quality of the leather will soften the door card and not require the foam. What are your thoughts?
Any insights or tips from your previous experience would be awesome.
