Page 30 of 36 FirstFirst ... 202829303132 ... LastLast
Results 291 to 300 of 354
Thread: Skoda RS replacement tyres - interesting
  1. #291
    Aug 2012
    Don't know about the Skoda (mine is delayed another 3 months), but replacement tyres in Canberra is easy. Just go to the Tuggeranong Tyrepower guy. Great service and reasonable pricing. I swapped the Pilot Sports on my Saab 93 to Falkens (top range) and they work with the chassis really well. Good $ too.
    If upsizing, you should also drop a size on the sidewall rating (45->40, eg) as it keeps the correct rolling diameter.
    Agree with you about the Khumo's though. Got nasty quickly.
  2. #292
    Adelaide hills, SA
    Quote Originally Posted by BottomScratcher View Post
    Transporter,
    Some questions.
    Which pads and discs did you buy? Did you do the rears as well?
    And what's that on your jack plate? A piece of wood with a channel cut through it to accommodate the sill seam?
    They are ATE Ceramic pads and ATE discs. Unfortunatelly there aren't ATE Ceramic for rear, so I have to wait when they become available.
    Yes, I use wood or rubber block to protect the sill seam. I don't like when they bent and get scratched.
  3. #293
    Jan 2012
    Earlwood, NSW
    Thanks for that. I just had a look online, and found an ATE distributor (HSY), but retailers seem thin on the ground. I'll give the distributor a call.
    The aluminium based paint coating on the disc in your photo had me wondering what it was. If the ceramic pads are half as good as claimed then not only will they perform well, but I'll spend a lot less time cleaning wheels, and my driveway.
    I'm the same with wanting to protect the sill seams. I tried the hockey puck idea, and the sill seam was still too deep for it.
  4. #294
    Nov 2012
    Algester, QLD
    Wow some awesome info about tyres, I pity all of you though for what you pay for tyres!!! I'm lucky to pay 200 a set for Achillies 123s track control tyres.
  5. #295
    Erskineville, NSW
    Quote Originally Posted by GTI180 View Post
    They are a drift tyre.
    How do they compare with something like a Michelin PSS or PS3 for wear, noise, ride, handling, dry & wet performance?
  6. #296
    Nov 2012
    Algester, QLD
    I'm not sure if they are used for drift or not, they are the control tyre for the Suzuki Cup Sprint series and that's why I use them, they are great in the wet, I don't feel I have to be cautious on them, stiff side walls gives out a little noise but that's what I have an exhaust for and as for tyre life, I'm on my 2nd set in 18 months, so by rights I'll get almost 4 years out of $1000 dollars worth of top notch tyres , sounds good to me, and at the end of the day if I destroy one on or off the track, I won't get upset.
  7. #297
    Erskineville, NSW
    How many km do you do per year?
    If you are on your 2nd set in 18months then 18+18 = 36 months = 3 years. $200/tyre x 4 =800 x 2 = $1600
    If they work for you, that's great but I've bought cheap tyres before & experienced buyer remorse for several years afterwards. Some of them have been so bad that it made you drive like a nob just to wear them out quicker.
    edit: Moot point anyway as they don't appear to come in any sizes that are OEM on any of the Octavias.
    edit again: Tread depth when new is 4.8mm compared to 8mm on most tyres. I usually bin my tyres at 3mm (minimum legal is 1.5mm). tread wear rating is 200. Doesn't sound like a value proposition for me.
  8. #298
    Jan 2012
    Earlwood, NSW
    [/QUOTE]
    Thanks for that. I saw DunlopRS's pic as well before it was removed. Both placards only in English, same part number, and showing a min speed rating and a min load index.
    My placard in Czech, Russian, German, and English must have missed getting changed. Nothing from the dealer yet.
    The planets are back in alignment, the earth is not about to be hit by a meteorite the size of Canada, and I have a new tyre placard the same as Mysticality's.
    To get this simple matter right has been a PITA. Based on a previous good experience I took the car to the same dealer that did the injector pipe recall mod. I don't know if there have been a lot of staff changes there, but in dealing with them to get this placard sorted I've already commented that it took 5 days just to get a call back to confirm that the placard was the wrong one.
    So, I get the car their well before the 8AM booking time, do the reception formalities, and head to the lounge for a coffee. In my mind it should only take a few minutes to peel a sticker off, and put another one on, but workshop procedures come into play, so I waited patiently .... until 9AM. I went down to see what was going on, and saw my car sitting there with the fuel flap open. The new sticker was on it. I asked if the car was ready to go, and after no comment other than to get me to sign the job sheet I was handed the keys.
    I didn't sweat it, and just thought it a good thing that I decided to go down to see what was happening.
    What was odd was when at 11:38AM I got a phone call informing that my car was ready for collection.
  9. #299
    Erskineville, NSW
    Applied with such love & attention to detail as well.
  10. #300
    Jun 2009
    Northfield, Adelaide
    It was Brad, if you look at it sideways you can see it's a smiley face, and I'm guessing it was fitted by the apprentice as there seems to be some "blemishes" on that smiley face as well . I reckon that takes dedication to his art..... ha ha ha
