Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Made some changes with VCDS today
    Erskineville, NSW
    Had a small muck around with VCDS (aka VagCom) today.
    • Hazard lights under hard braking enabled
    • Scandinavian daytime running lights enabled
    • DRLs dimmed from 92% back to 50% - will be changing this to 75% as I'm told lower than 70% reduces bulb life. Does anyone know anything about this?
    • Enabled foglights to act as cornering lights when turning.
    • Enabled foglights to act as cornering lights when indicator turned on.
    Not sure what other tweaks are left. Any suggestions?
    Jun 2009
    Finally someone whose actually done this! How can this be done Brad? What about the colour of the dials/interior lighting?
    Just thought of the passenger mirror dipping when reversing too.
    Mine: Silver 2006 Volkswagen Golf Sportline 2.0FSI 6M (with a sunroof)
    Parents': Candy White 2008 Skoda Octavia RS 2.0TFSI 6M Liftback
    Adelaide hills, SA
    The sunroof and windows automatically closing in rain. Yes, that's truth the life of the globes is reduced when you dim them.
    Erskineville, NSW
    Quote Originally Posted by Jake02 View Post
    I set the passenger dip as well (I knew there was something else). Haven't tested it yet. VCDS says you need memory seats.
    Didn't really look at interior lighting. Because mine is preFL I can't enable needle dance at start-up. You can enable various door handle lights once you physically fit the lights (ie: like they have in the L&K models).
    I've had this cable since August last year (gift from a mate who gave up on VW) and not made changes - wasn't really sure what would happen. Still wasn't sure today but found a few guides on youtube. Some stuff was beyond me (changing the hexadecimal number rather than ticking a box), so I avoided that until I have a better understanding of what I am doing.
    Rain closing windows were already enabled on my car.
    Jul 2010
    nice
    was it hard to enable the cornering foglights??!?!
    i wanna get mine done one day......
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Erskineville, NSW
    Quote Originally Posted by dArK5HaD0w View Post
    nice
    Nope. 5-10 minute job. 3 settings?
    My biggest problem is I don't like sitting with the ignition on...... & the laptop battery is on the way out & I'm scared it will die halfway through the process.
    May 2011
    Cronulla, NSW
    Ooh this thread has got me tempted to have a play around on my MY11 VRS. The cornering foglights and passenger dip sound handy.
    Couple of questions, I know you can get cheap vagcom cables on ebay. Will these do the job and is there any particular model/connection type I need to look for?
    Is doing this grounds for voiding factory warranty?
    Thanks in advance.
    Adelaide hills, SA
    Get the 240 extension cord out, connect laptop to main power and connect the battery charger to the battery. Other things you can try; change the screens (color scheme) in Columbus radio with VCDS, fix the error in fuel gauge, adjust parking sensors distance for the tow bar, if you have one. You can also test the actuators (like horn. to see if the fault is in switch or horn) and so on.
    Mar 2011
    Annandale, NSW
    Thanks for posting, didn't realise you could play with some of this stuff.
    Erskineville, NSW
    Quote Originally Posted by drc13 View Post
    Thanks in advance.
    I've got simultaneous adjustment working. Mirror dip still eludes me.
    I tried a cheap $45 cable from dealextreme & it didn't work. Car is too modern.
    Shouldn't void warranty AFAIK.
    Yeah, couldn't be shagged getting the 240v out.
    Oh, I hopefully corrected the error in the fuel consumption read-out. Actual was 6.6/6.7. readout was 6.4. New value was 103 instead of 100
