Results 1 to 5 of 5
Thread: Columbus trim surround part No
    Dec 2006
    Kilsyth, VIC
    I replace the stock radio for someone in the last week for a Columbus nav unit (which in itself was easy enough), however the trim surrounding the radio and air con controls is different for the columbus and it seems that finding the right part is a bit of a nightmare.
    This thread here:
    Octavia II columbus fascia surround - BRISKODA.net - The Skoda Forum and Community
    talks about part no 1Z0858069B9B9, but ETKA doesn't seem to think it exists and while it lists different fascia/trim bits, not seem to be the right one for this install.
    Does anyone have the Columbus unit and want to pull the silver surround out and read the part number off it for me?
    Do you a deal if you have access to ETKA: can you get me the part numbers for rear light assemblies for Octavia 1Z FL Kombi vs Liftback. Are they different numbers?
    Facia for stereo/climatronics in mine is 1Z0 858 069 DK DF1
    Dec 2006
    Kilsyth, VIC
    1Z0 858 069 DK
    Is listed as:
    Trim for switch for vehicles with navigation system
    air-conditioning system with electronic regulation
    1Z0 858 069 DK DF1 is the "light tonal brushed" version (ie different colour).
    In his case he has the manually controlled air conditioner so it's going to be a different unit.
    There are at least three different units shown:
    And even then there are a butt load of part numbers, the ones JUST for item 9 are:
    trim for heater switch:
    1Z0 858 069
    1Z0 858 069 9B9 - Satin Black
    trim for heater switch for vehicles with navigation system:
    1Z0 858 069 D
    1Z0 858 069 D 9B9 - Satin Black
    All these are listed as D >> 06.11.2011 which I assume means "PRIOR to 06.11.2011"
    1Z0 858 069 CT
    1Z0 858 069 CT 2AU - finely turned aluminum
    1Z0 858 069 DA
    1Z0 858 069 DA 2AU - finely turned aluminum
    1Z0 858 069 DB
    1Z0 858 069 DB 2AU - finely turned aluminum
    1Z0 858 069 DC
    1Z0 858 069 DC 2AU
    All these are listed as D 07.11.2011 >> which I assume means "AFTER to 07.11.2011"
    1Z0 858 069 DR
    1Z0 858 069 DR WD1 - Dark Silver
    1Z0 858 069 EJ
    1Z0 858 069 EJ WD1 - Dark Silver
    1Z0 858 069 DM
    1Z0 858 069 DM WD1 - Dark Silver
    1Z0 858 069 DN
    1Z0 858 069 DN WDA - Dark Silver
    1Z0 858 069 EA
    1Z0 858 069 EA VL8 - Cinamora wood
    The list for items 10 and 11 are even longer Now there are model details listed against each one, so I think if I had the manual I might just be able to work something out, although even then I'm not 100% convinced. I get the fact there is different colours and even a change at a particular year model/variant, but this just looks crazy complex for no good reason.
    It looks like all the "11" parts are for "Trim for switch for vehicles with navigation system, air-conditioning system with electronic regulation".
    And all the "10" series parts are for "trim for switch with manually regulated air conditioning"
    Series "9" is everything else??
    In my case I *think* it's a "9" series part, just need to nail down exactly which one is right.
    Dec 2006
    Kilsyth, VIC
    Do any of these images help you:
    Thanks.
    Confirms that they are indeed diffferent part numbers. Clears something up for me.
