Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Engine fan running after engine shutdown
    Nov 2010
    Perth
    Parked the vRS in the office (undercover) car park, shut down the engine, heard a constant noise, thought it must be someone elses car running.
    Got out a minute later and realised the noise was coming from the cooling fan under my bonnet.
    It kept running while I waited (~3 minutes) for it to stop, was slightly worried (welded contacts on a relay?). But couldnt wait any longer so went and disposed of my bag (thinking: gunna get a flat battery!).
    Came back 5-10 minutes later, it had stopped.
    Had my toy now for 6 months and its the first time I've ever noticed the fan. Bloody sure I would have heard it before because the noise is loudish.
    I wasn't running the car any harder than normal on the way to the office and it was a cooler morning anyway.
    Abnormal ??!!
    If its by design, WTF would you run a fan instead of letting it cool naturally?
    Joy Toy: 2010 Skoda vRS - Metalic Black - Liftback - TSI - 6sp Manual - Leather - Sunroof - Fiscon Plus
    Jun 2009
    Northfield, Adelaide
    Mmm unsure why a TSI would be doing this, but it can be common with the TDI, as it usually means it was trying to do a DPF regen which causes the engine to run warmer then normal. Normally I will restart the car and let it run for a minute or so, enough for the engine to coolback to nromal temps.
    Where you giving it hard time through traffic and didn't give it time to cool?? Remember once you turn it off the coolant no longer circulates so the cooler radiator fluid has to heat sync back to where the temp sensor is which is normally on the engine
    Jul 2010
    Brisbane, QLD.
    Had the exactly same thing happen to me a few months ago. I had been driving around for 15mins trying to find a carpark. When I finally found one, I locked the car and started walking away when I heard the noise coming from under the bonnet. I didn't know what was going on so I waited a few minutes and it went off.
    As soon I got home I went to my number one site for Skoda information (this fourm) and I found a post from 2 years ago about it. Basically it is what Dazag said and the electric fan kicks in to cool the engine (maybe turbo) down.
    After having a WRX a few years ago, it had a little sticker telling you to let the engine idle for a minute after hard or long driving. If I have been driving the Skoda for a while, I sit in it for a minute or so with the engine running to cool the turbo down.
    Probably as I was running late on the night I described above and thinking I hadn't been driving it hard, I didn't wait when I turned the engine off, hence the fan running.
    Skoda Octavia RS Wagon TSI DSG Candy White MY10
    Sep 2009
    Quote Originally Posted by Gnat View Post
    Because if you don't you would have cooked the turbo and the you'd be here complaining about a dead motor and a huge bill.
    It's quite normal for turbo charged cars to have fans that will come on after the engine is turned off to force cooling because when the engine is turned off it actually continues to heat up for a period and there is no forced cooling through air flow or the cooling system. Turbo charged cars have had this feature since the early 1980's and the only new thing about it is that it's the first time it's happened to you.
    My Škoda photos here
    Flickr : Blog
    Adelaide hills, SA
    It also prevents the hot spots in the engine's cooling system. That feature is also on Honda and some other makes from at least 90' and they don't have to have the turbocharger.
    I'm surprised you have never seen it especially in summer, on hot days mine does it every single day.
    Oct 2009
    Northern Suburbs
    Abnormal ??!!
    Even when you turn the motor off it continues to increase the tempreture of the motor. This is known as "Latent Heat" is is quite normal.
    VW like most other European manufacturers has for more that 40 years have used intelligent fan driven cooling systems to manage and dispurse "Latent Heat". Its covered someware in your User Guide. More information http://en.wikipedia.org/wiki/Latent_heat
    Jul 2010
    Castle Hill, NSW
    My RS did this for the first time the other day as well, it's definitely normal.
    I didn't worry about it as most of my previous cars have also done this from time to time, although the fan does seem to stay on a lot longer in the Skoda compared to my Mazda.
    MY11 Octavia RS 2.0lt TSI DSG Liftback - Candy White
    Feb 2010
    South Perth, WA
    Recently our Jetta TFSI did this and when I enquired at the following service about it, they ran some checks and found that the main thermatic fan had failed and that the secondary fan was running constantly trying to cool the engine. Had the main fan replaced and all is good now! The most my R or the Jetta runs the fan is approx 1-2 minutes after shutdown even on very hard runs, though I do let the motor cool by driving easy on the last km or so on the way home.
    It'd be worth checking and if the fan is faulty get it replaced under warranty as it cost me about $600 out of warranty!
    WLF127
    Erskineville, NSW
    When you turn off, there are several components that keep running depending on engine temp.
    1) turbo cooling - almost always. It's either an electric oil pump or an electric water pump that circulates the fluid through the turbo to counteract the post shutdown temperature rise (due to no airflow through the engine bay).
    2) radiator fans. These will run for up to 10 mins to mininimise engine bay temperatures - brilliant idea IMO as it makes plastics last longer. You won't flatten the battery unless the battery is on the way out anyway. This is why VWs run a huge mofo of a battery compared to (for instance) a Subaru Liberty. Even my '98 Golf Cabrio had the post-shutdown fan thing happening.
    In light of Shakespeare's problem, wouldn't hurt to have it looked at or at a minimum, if you hear the fans running, check to see if both are working.
