Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 76
Thread: 60,000km service
  1. #51
    Erskineville, NSW
    Quote Originally Posted by Skooter View Post
    Thanks for the tips on the VCDS, Brad. Any idea what level would be required for basic diagnostic? They offer about 4 different packs in ascending order of price. I can run the Mac in Windows so would probably just use the laptop. Not going to be plugged in very often, hopefully.
    i have no idea - best you ask them.
    I have a can-bus unit. A mate gave it to me when he sold his R32.
    The diesel area is probably the best place to talk about remaps & provents. I think you'll find it's a thumbs up to both.
  2. #52
    Jun 2011
    Hi all,
    I was just searching the forum for advice and comparisons on 60,000kms service on a Mk6 Golf GTI, where my actual odometer is on 53,000kms. Got quoted $1395, then when I pushed back they asked if I had a DSG or manual, then petrol or diesel. Quote then came down to $1100. I checked with an independent mechanic who has done other cars in the past and he said $300 tops. Does anyone else find these outrageous quotes for spark plugs, oil changes, air filters and the like an obscene slap in the face?
  3. #53
    Erskineville, NSW
    $300 tops is BS unless he is using non-genuine parts, incorrect oil & doing his labour for about $50/hr.
    I would run as fast as I can if an independant quoted that as he obviously isn't overly experienced about VWs. Ask these two questions: What brand of oil filter will you use? What spec oil will use? Answers: "Gen VW, Mahle or Hengst(sp?)"; "504/507"
    For an experienced VW tech using OEM spec parts & proper oil the non-ripoff ball park is $450-$600.
    You really need an itemised quote or provide a list of the work you want done so that you can compare apples with apples.
    Some will include tyre rotation in a 60,000. Other include spark plugs ($25 each), brake fluid flush ($100-$200), pollen filter ($25), air filter ($25), fuel filter ($45) and as you implied, a DSG service might be needed if you have that transmission ($300??).
  4. #54
    Dec 2008
    Sydney/Canberra
    $600 for a manual MK6 GTI.
    Includes fuel filter, spark plugs, and pollen filter on top of the basic oil and filter change. All genuine parts.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  5. #55
    Dec 2010
    Ringwood East
    I just had my 60,000km service, it was $245 form Preston Motors Epping. I had reported a clunking sound and vibrations in the DSG so they suggested I did a DSG service as well to hopefully fix the problem which was an extra $732, so it ended up being $977 and the problem is still there.
    NOW: MY15.5 Race Blue RS
    THEN: MY10 Black Magic RS
  6. #56
    Jan 2013
    Preston, VIC
    I was at the point of doing my own oils and filters, so frustrated have I been with the inability of any authorised dealerships to explain the $1k costs. I've since found a VERY experienced independent with years of experience on VW group cars; quote is $600, add $200 for 2 x Haldex oil and filters for the 4x4 Scout, full diagnostic - all gen parts (he even passes on some of his trade price savings), top quality oil (Motul).
    He also said he won't change pollen and air filters if they look in top nick, which is highly likely, as the car has had a cruisy life, but I don't care either way. I just want to know that a mech with more experience than me with this car will be doing the work - otherwise I do it myself.
    I'll report back once it's done and give feedback.
  7. #57
    Dec 2008
    Sydney/Canberra
    Only 1 Haldex oil is required for the Scout Not sure what version of the Haldex system they have, so it may or may not require a filter change.
    '01 Beetle 2.0
  8. #58
    Erskineville, NSW
    Quote Originally Posted by Fireside View Post
    That's a good price. I can't quite see how they could do oil + filter, pollen filter, scan, brake check, tyre inspection & pressures, battery insp, plenum insp, door locks, underbody, suspension, steering, drivetrain & engine inspection, coolant test, etc for that money so it implies they may have just done a Standard Inspection service
    The DSG isn't optional at 60,000km -it's mandatory unless you already pulled the trigger earlier (I would). Or is it a 7 speed?
    Diesel or petrol?
    How many years old is it?
  9. #59
    Jul 2013
    60,000km service
    Anyone know if Ultratune will service skodas and anyone have any experience with them? There's an ultratune very close to my house so highly convenient!
    Also is it generally the best practice to service at the dealer whilst sill under warranty then go independent once warranty expires?
  10. #60
    Nov 2009
    Illawarra NSW
    I don't think you can generalise all Ultratunes. They would be all independently run. There is probably good and bad.
    2014 MY14 Corrida Red Elegance Wagon TDI
    2009 MY10 Race Blue RS Wagon TSI 6 sp. manual. (Gone)
    2011 MY12 Yeti 77 TSI DSG.
