The plug on the rear of the lamp is crap..seen this before..the plug is held onto a mount plate and you push the headlamp back into the plug to make the connection...remove the headlamp and refit it nice and tight back in then try... sometimes works..if not you might need to mod it a bit to make better contact...headlamps can be a bugger to remove... VDUB...
