Results 1 to 10 of 15
Thread: WTF is this noise coming from the block... please helpppp
    Jan 2011
    Gold Coast, QLD
    Hey guys,
    Drove the car last night just fine, tonight I start the car and I am greeted with a screwed up noise coming from the engine.
    Please listen to the sample.
    https://skydrive.live.com/redir?resi...AnGOxuBJsLevb8
    Does anyone have any idea what this noise is?? I quickly recorded it and turned it off.
    Thanks
    Jul 2009
    Geelong, Victoria
    mmm... check that nothing is touching where it shouldnt - that belts etc arnt being interfered with, no loose hose touching anything etc.
    check oil level too
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    Jan 2011
    Gold Coast, QLD
    Ok should the timing belt be .. like.. fully on the camshaft sprocket.... Im thinking yes.. but im not a professional mechanic.
    btw thanks for the ideas Stan.
    Jan 2011
    Gold Coast, QLD
    Can anyone confirm that the image is not normal?
    Dec 2012
    Sutherland Shire, Sydney
    I've never looked at a VW timing belt but have worked on heaps of Fiat's, Lancia's and Alfa's
    The timing belt does always not run in the dead center of the wheel
    If there was a problem it would be off the wheel quicker than Tony can put his foot in his mouth
    Listening to the audio recording,
    there is a rapid and high pitched sound similar to parts interfering, it is concerning
    Is this a manual - what happens if you push the clutch down? (checks the release bearing)
    Here is an idea that may help - it's a bit daggy
    Get a piece of wood - a broom stick or something
    Press it against the water pump and then put your ear against the wood
    Wood conducts sound really well and you will know when you've located the source
    Next try the alternator
    Not much point putting it on the head or rocker cover as there are heaps of moving parts all making sound there
    You need to know what is normal and what is bad to make sense out of sounds from that area
    You really need somebody that can help to have a look at it - take it into the workshop
    Sep 2009
    brisbane
    yeah i wouldn't be driving it mate. could be something as single as a heat shield loose, or it could be something much more serious. id get it checked asap. btw my cam belt looks the same as yours so i don't think its that
    Jan 2011
    Gold Coast, QLD
    Thanks Martin,
    Ive contacted the guys at CVWC and they are going to take a look at it on Monday.
    Jan 2011
    Gold Coast, QLD
    Quote Originally Posted by Lito View Post
    Oh really?
    The only reason I thought it was unusual is that I found an image of a passat 1.8t, and the timing belt is 100% on the sprocket....
    Dec 2012
    That timing belt is the same width as the wheel - it would be in trouble if it was partly off the wheel
    When the belt is more skinny than the wheel - it could be left/centre/right
    Jul 2009
    Geelong, Victoria
    as always internet diagnosis is careful guessing at best for most - martin's suggestion of taking it to proper help is best.
    Let us know how it goes
