Results 1 to 10 of 10
Thread: Whats the wrong? Misfire?
    It sounds like either a leak after your MAF where it's sucking air or posibly a faulty MAF (quite common in the older Mk4's. Try disconecting it and see how she runs, Look for posible a clip missing after your airbox where there could be air leaking ing too.
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    Nov 2006
    Im curious about the car - Shortening the gear ratios is not an easy task - Are you sure thats what has been done?
    Tuning the car for high RPM is interesting too - The turbo in these things is so small it is basically useless over 5000rpm and no amount of tuning will make a difference.
    Maybe he has fitted an aftermarket cam, if it were aggressive enough it could cause the car to run rough at low RPM and open up as it gets higher. But the car would either be idling like a pig or idling way over 1000rpm.
    To do all that he'd need an aftermarket ECU too - Coupled with a cam and a shorten'd ratio box... sounds very unlikely.
    Something is probably wrong.
    Aug 2007
    doncaster, vic
    could be a boostleak in the standard intercooler piping. or like 99gti said the MAF. they are so tempermental. mine did that some time ago....exact same symtoms.
    MK4 GTI|REVO|4BAR ADJ FPR|APR FMIC|APR R1 DV|TURBO INLET PIPE|KONI|WHITELINE|CUSTOM CAI + K&N|2.5" TB + HI FLOW CAT| ECS DOGBONE
    Canberra
    Does the car have the stock airbox/filter fitted or is it an oiled K&N type filter?
    Snowy.
    Sep 2007
    Syd, Northern Beaches
    He has the stock airbox so no K&N. Im thinking coilpack too. I originally said sparkies but they werent the problem. It feels like a spark problem but yeah could also be a number of other things.
    (]/_ O _____ O _\[)
    "'(O8o)=\X/=(o8O)
    [__|========|__]
    Dec 2006
    Metal connectors with the MAF ?
    -DIDZ
